Grease gun storage solution
sgtmac
Wilmington ,nc
I have a dedicated "lube cart" for grease guns, LPS etc. it's convenient to roll it where your working at.
I kept piling my grease guns in the top and it made a giant mess.
I came up with this idea to keep all the grease gun ooze away from my guns as much as possible.
I took some scrap lumber and made a box that fits the top of the lube cart. The sides are 12 inches and that is deep enough for my grease guns to fit without bottoming out. I Added 3inch holes for the guns and 5/8 holes for the hoses.
I put a layer of pig mats to absorb the grease goo.
Only need to re label the top of the guns with the appropriate flavor of grease so it's easy to choose.
Fcvapor05
Nice.
I will say, you must do a hell of a lot more greasin' than I do.
Chadwilliam1
Cincinnati
That is a brilliant idea. grease guns are messy, i see you dont have any hard tube just flex hoses. What kind of grease guns are those.
sgtmac
Wilmington ,nc
The grease guns are the $16.00 ones from zoro tools.
I run an aircraft repair shop and we do a lot of greasing with a lot of different types of greases.
RECox286
South Joisey (yeah, that is part of the USA)
I hope everything is labled. It's too easy to put the
wrong stuff in the right hole ! (Or the right stuff in the
wrong hole...)
I also remember one day that turned into a witch-hunt.
No maintenance happened all afternoon, except that finally the
Airman who went to lunch and then home for the afternoon
was finally located, er should I say the screwdriver tip in his
pocket was accounted for. (Whew !)
Uncle Bob
katy
I just use an old metal 5 gallon pail, hang the guns and the ends of the flex hoses into the pail.
Grigg
Lexington, VA
Mine hangs on a hook on the side of a cabinet and beside it a tin can for the hose to drop in.
Then occasionally the body of the gun would drip, so I slipped an old sock over the tube/body of the gun and leave it there, no mess and you have a rag handy to wipe your fingers off if necessary.
aka rotten
Mine 16" long pc 3 in pvc. Cap off one end. One pc 1"pvc. glued to side of 3in.gun slides down in 3 ", hose end in 1".Mounts to shelf where I keep oil and such. Works for me, only have two grease guns thou. Those measurements from memory, you might want to adjust a bit
JKady
Spanaway, WA
I'm surprised you're using hand operated guns if you do that much greasing... I love me electric and I use it maybe once a week.
Chadwilliam1
Cincinnati
He would need several electric grease guns. He may not do that much greasing but need a variety of grease for different applications.
PFSard
Mesa, AZ
I'm saying to myself that this sounds good, but I cannot picture this in my mind's eye. Do you happen to have a pic of this setup?
Thanks
Paul
tomshep
Just a couple sections of plastic pipe 16" in length with caps on the ends. One size for the gun, one for the hose. I like this idea!
Tom
Provincial
Near Salem, OR
I use a piece of 3" PVC pipe with a cap on the bottom, The gun hangs with the handle outside. I plug the hose with a 1/8" NPT zerk screwed into a pipe cap.
I keep the zerk "plug" loose. I thought of tethering it either to the pipe or the gun, but decided that this would be too messy. Tethered to the pipe, the zerk would be hanging loose and dribble grease. Tethered to the gun, it would be exposed to dirt as it was dragged around the job. With it loose, I put it on a rag and clean up everything when I plug the hose to store the gun.
I keep a rag on the edge of the PVC pipe to protect the ram of the pump and also to soak up any leakage from that area. I find that all my guns seep a little around the head, ram, and the tail where the push rod emerges. I have to wipe them off regularly. NAPA, Alemite, and Lincoln guns all seep a little.
