Grinding disc storage
KSeriesChevy
Indiana
Wanting to see what you guys do to store them or organizers you have built/bought. I have so many in a bucket and would like to find a better option.
Strouty
Southern Maine
I have been thinking of hanging them on a rod or pegboard hook. Right now I usually buy them in boxes of 25 and just keep them in the boxes. The thing about that is I have no idea of how many I have left, so I run out from time to time in the middle of a project.
North Run Grader
Swan Hills, Alberta
When I start finishing my garage, I plan on adding a section or 2 of french cleats above the work bench. I have 4", 4.5", and 5" grinding and cutting disks to organise. I think about a 2' section with 6"x1/4" dowels or bolts spaced roughly 6" apart will allow me to visually keep track of my stock. It depends on how many sizes and styles you keep in stock. With a french cleat system I can adapt or expand easily with scrap plywood and a little time.
sberry
Brethren, Michigan
I am not uber fussy, I want to see if I am running low on a regular stock item but have a cab below a welding booth and an old tech tire cab for most bits related to welding. Any extra is mover to an out of the way drawer.
alfazer
N. Ireland
Some kind of flip storage in a box. Like how 3.5" computer disks used to be stored, or maybe CDs.
Not that I do this, but your thread has me thinking about it.
lakeroadster
Central Colorado
Ahh NUTS!...specifically peanuts.
I store mine in empty Planters peanut containers. The containers are clear and 4-1/2" discs fit in these like the container was made for them.
And the shape of the containers allows you to stack them too.
bullnerd
Jersey
Not mine, but I plan to do something similar IF I ever get my shop ready to actually work in. It'll say Hammer, instead of Hester.
77Mini
Ontario Canada
The mastercraft discs happen to come in a convenient storage spindle.
http://www.canadiantire.ca/en/pdp/m...-cut-off-wheel-set-0541037p.html#.VpqwhVJk95c
They also happen to go on sale for filthy cheap. At sale prices it doesn't matter that they only last 1/3 the time as a walter, they cost 1/4 the price.
I stopped buying the Mastercraft ones. Yes they are cheap but they wear our sooooo fast. I just find them a pain. I'll use up the ones I have and buy good ones from now on.
they do have one set that comes with a metal case. i have thought about buying that one just for the case.
Thumper68
Duluth MN
I keep mine sorted in the bottom drawer of the chest under my drill press, there are about a 100 4 1/2x 1/4 and all the flap wheels and cut off disks in there all sorted by size and type.
bullnerd
Jersey
Bullnerd, I like that setup. I am guessing you made it?
No Sir, not mine. I am going to copy it though, that's why I have the pics. You can see Hesters stuff on IG. Theres another guy (Rago Fab) building a rack that looks very similar to these for holding tig rods also, looks pretty handy.
metalmagpie
Seattle
I swear, you guys must have ACRES of shop walls! Every storage question gets a bunch of answers that involve many square feet of open accessible wall space. My shop has very little open wall space because I have machines and shelves in front of my walls.
I store grinding wheels in a drawer. Very space efficient. And I keep enough grinders so I probably have one tooled the way I want. Those I keep on a freestanding rack behind my welding table (with metal stock leaned up against the wall behind). So I don't need to store a ton of grinding wheels - what I own is mostly on the grinders. My motto is (when I can) "let the store store".
metalmagpie
sberry
Brethren, Michigan
I agree, would be out of room.
sberry
Brethren, Michigan
I think many of these features were built as a hobby and earlier on in procjects where the room looked huge. Steel racks the same way, I could actually out 10X in the same space and do. The early vision is 20 ft lengths which soon become shorts and I don't buy anymore to stock per sa.
These racks were pieced together, with another revision could actually be improved and organized some yet. I have been trying to use more than I gain and may strip some off not used to less valuable real-estate. There reaches a point where its easier to remove than to keep adding.
I can and might build a mezzanine yet but it hasn't become a reality due to the fact while its a nice feature I really don't need it. I was contemplating a 1500 footer in my storage and about 3 or 400 in my shop but if I toss some junk and stack a bit more I can do without and end up with a few ft of shelf.
sberry
Brethren, Michigan
In a small garage or shop the shoe box method would work for me, toss in a drawer or on a shelf.
ZRX61
Solar Blight Valley, SoCal
Drawer in my "welding stuff" toolbox.
https://scontent-lax3-1.**.fbcdn.net/hphotos-xat1/v/t1.0-9/10274140_10202767191813669_4352515842168399307_n.jpg?oh=e7465a8cec198da6ab26a3da77ebc1c1&oe=56FE893E
RogueFab
Oregon
Ours are on nails in an old workbench and bulk storage in boxes on the bottom shelf. Simple. Good enough for now.
bullnerd
Jersey
Yeah man, Totally agree on the wall space. Its just one option, not for everyone. Hester is the real deal, not a hobby shop or a farm shop. He has a lot of pride in his shop and work. Everything is very well organized.
Truck Guy99
West Oklahoma
6 inch long pegs on my pegboard do the trick for me. I keep all my power tools on pegboard over a metal table I only use for metal fab so all my stuff is there anyway
Sanddancer
I'm only a DIY tinkerer, so don#t have that many to store and just use a diddy 4.5" grinder, but I get these from work and they're perfect. One each for grinding, cutting and flap discs.
zkling
x10 :lol_hitti Mine are in a drawer, it is packed.
sberry
Brethren, Michigan
I have 6k ft and watch the space very carefully. It would go fast. My goal every day is a clean bench and as much moved on as possible or practical.
stage20
pcola FL
Don't have any life of my old welding bench. I welded solid rod bent to a 90 degree and welded it to a leg. Had 4 of them for various types wheels. They were roughly 4in by 16in. Could really stack a lot of wheels on them and they were in plain sight to see what you had. I have more room now and have a dedicated 40 inch box for all of my metal working and welding tools so they are now in a drawer
