Grinding JB Plastic Weld
ukiltmybrutha
I have to grind some JB Weld off of a bumper ridge and the clearances are relatively tight. I have a dremel tool but wasn't sure what the right bit for that might be? I'd just try anything but the bumper is rather rare.
Any ideas?
Thanks.
tarmy
Nor Cal
How about a fine grit 2” wheel on a right angle die grinder...that is where I would start...with the speed set as low as possible...
subroc
Dover, NH
I just filled some holes using JB weld. The 2 holes that were on the flat surface I used a ROS with the dull sand paper that was in the thing. On the profile surface I used the ROS with the same dull paper and hand sanded with some folded 120 grit. It comes of reasonably fast. Seems a bit harder to sand than say, some bondo filler. But, not by much.
Good luck
