mobiledynamics
Do I need to run a Ground Wire Between my Transfer Switch and Main Panel
Main Panel - Flex Conduit to Transfer Switch.
Transfer Switch has the following wires run to the Panel
Neutral
Ground
Common Wire
Branch Wire
Is the metal connection between the 2 panels sufficient enough ?
All my ~home runs~ don't have ground (BX land, all AC wire to my main panel).
If so, do I install the ground to the neutral bar ? I don't have a ground bar in my panel
Neutral
Ground
Common Wire
Branch Wire
