Very cool project.
I probably missed something, but if not, you really need to support the body on the frame rails for pulling, especially if you use a slide hammer; if not, the suspension will soak up much of the impact force.
Great point. This is something that I have thought about, and I have three reasons why I am not too terribly concerned with the suspension soaking up the force.
- The metal I am pulling is pretty thin, some of it is 22 gauge, so I'm not expecting it to require a ton of force anyways.
- The car is sitting on some really stiff coilovers which are also progressive coilovers, as in they are more resistant as they compress. So with the jig pulling the car down already, they will be even stiffer and resist the impact of hammering to an extent.
- If I find the suspension is working against me, I can easily take it out of the loop by using wood or steel to prevent any movement of the suspension.
That is my thinking anyways....
Well, it's been a couple weeks since my last post, so now is a good time to go ahead and update this thread. The last two weeks or so have been rather busy, not because of the GT-R, but because I made the silly decision to go and buy a truck that needed an engine in it. I started a thread on the truck over on the Ford-Trucks forum (Link:
https://www.ford-trucks.com/forums/1680906-96-f-350-la-wawa-verde.html) if anyone is interested. Here's a portion of the first post I made....
"I just made what is arguably a poor financial decision and bought a 96 F-350, crew cab, dually. Unfortunately, it needed significant engine work, potentially an engine replacement, and had been sitting since 2005 sometime. Fortunately, I was able to talk the seller off his price quite a bit and also worked in him delivering the truck in the deal. Could have been better... but I ain't complaining. Anyways, here she is once she was delivered....
Once it arrived, I got busy with figuring out what was wrong with the engine. The person I bought it from believe it had an issue with leaking coolant into the oil due to bad o-rings/seals on the oil cooler (at least he said); however, one climb underneath the truck proved it to be a much worse issue. Turns out it had tossed a rod, there was a significant ding in the oil pan where the rod had hit and the block had chunk knocked out of it. So began the process of pulling the engine and trying to find a replacement.
I ended up finding an engine about 4.5 hours from me, and since I had not truck, I had to rent a Dodge Ram from Enterprise to go pick it up. Gotta say, this engine moved this truck around on the highway; no quick stopping or swerving at all.
The engine did come out of a higher mileage truck that had rolled, so after I got it home, I went ahead and resealed it and freshened it up a bit. Once that was knocked out it was time to pull the old engine. Out with the old....
In with the new!!!! Well, new to the truck.
At this point, I have 90% of it buttoned up. The only thing I am waiting on is a PCM and the core support bushings (right now I just have steel spacers to hold it in place), and a couple other odds and ends. Fingers crossed this pile starts after that. If it does, then I get to start working through all the other issues that likely exist from a decade and a half of sitting....... "
So the last two weeks have been hectic, as you can see, the GT-R had to come down off the cribbing so I could fit the engines for the truck into the garage. Space was TIGHT with those two in there.
And the garage proceeded to blow apart as I was digging out tools and not really cleaning things up as I went.
Anyways, I spent some time yesterday getting things cleaned up so I could actually work in there today because I had a package come in with some stuff for the GT-R.
A bit over a year ago I cut the cowl top side braces off the car in preparation for repairing the cowl. The braces I cut off were rather damaged by the time they were off the car, so I wasn't going to be able to reuse them. In addition to that, Nissan does not produce and sell these braces anymore, so I had to find a set off another car. They arrived a few days ago and I was able to get them installed today. Below are some before and after pictures to give a good comparison.
There they are, welded on to the car, dressed up a bit, and with some primer over them to hopefully hold off the rust until this thing goes to an acid bath.
I'm hoping I'll get to the rocker panels in the next few weeks, but as of now, the truck is taking priority over the car.
