ClearWaterMS
Short version: how should I run a gutter down spout so that it isn't in the way.
My garage is detached from the house to the north. My garage is located only 4' away and runs parallel to the house.
Here is an image
The walkway between the two is the only access to the back door which is the primary entrance for access to the house.
When you get to the back of the house, you can see the entry door (with the farm house light over it) in this picture
The garage has concrete on all 4 sides. The necessity of a gutter is for the slippery condition that is created when snow melts off of the garage and lands on the concrete causing a freezing condition. Every location I conceive for a downspout has the water either going across the pathway taken to/from the main entrance to the house. If I have it exit the front and have the water run down the driveway, it will create a slippery driveway which would be dangerous for guests even when the use the front door. If I have it exit the back, I either have it long enough that it creates a tripping hazard to the man door, or i leave it short enough that it deposits the melting water onto the concrete and causes a slippery situation.
Is there something that I can put over the door that isn't hideously ugly that would divert the water to the other side of the door towards the garbage cans and into the yard?
Here is an image
