Hammer time!
Maybe
Are the initial cast or milled in? those almost looks milled
Maybe, I didn't get out a magnifying glass back then. Looking into it now, it's full of gunk, so I can't see milling machine marks, or casting marks. Can't clean it up right now, on a video call with Schwarz right now, he wins. More here later.
MisterEd
Florida
An unexpected discovery at a sale this weekend; Heller, 16 oz, Regular Ripping Claw.
NYBODYMAN
NY
Got three hammers in a small lot of tools I bought this past weekend. The first one on the left appears to be a heavy duty bumping hammer of some sort (I've never seen one like this). Second one is a USA made sledge. and the third is a DISSTON USA. Anyone know what the DISSTON USA hammer was used for?
MisterEd
Florida
Bell System Stanley Three-Pound Driving Hammer
"Driving Hammer is a three-pound hammer having a striking face on one end and a straight peen in the opposite end of the head. The head is provided with a hole to facilitate straightening pole steps. It is intended for use by construction and installation forces in driving the heavier nails, lag screws, etc." As stated by Bell System Practices.
Pre-1960 it was a Lineman's Hammer. Wondered about the reason for the hole.
NYBODYMAN
NY
Nice! Post this on the Bell System thread. I've never seen one of these as my father worked underground in NYC and not on poles.
MisterEd
Florida
The SigO handed it to me this morning and my initial reaction was a paraphrase of a line from Crocodile Dundee; "That's not a hammer. This is a HAMMER."
She and we found a few more things to post there soon.
I pulled this out of a Craftsman socket set box yesterday. It had some sort of sticky schmutz all over the handle - like glue, maybe? Head was a bit rusty. I cleaned it up a bit. Took the handle down with #0000 steel wool and rubbed some carbauba wax on it. I think that will be good enough. Head still has what appears to be dark blue paint on it. Interestingly it appears to be a dead-on match to a "Westline" that I have here - what a coincidence, eh? ;)
Stanley 306 4-ounce ball peen hammer
Shiftless
East Bay SFO
A couple of weeks ago I stopped by an unadvertised neighborhood yard sale near closing time. There sat this beat up neglected Estwing. I picked it up off the ground and the guy said that he was a plumber and found it under a house. I could have it free. Maybe I should have left it there but I couldn’t help myself.
Just needs a bit of a clean up. 😎
Shiftless
East Bay SFO
That will definitely buff out! (y)
You’re right outlaw…
It did buff out.
For the stacked leather handle, I sanded it with a medium sanding sponge and then with 220 grit paper. Then some walnut wood stain and more light sanding to even up the color.
Finished off with a few coats of satin lacquer.
(It’s hard to get a good photo of a shiny object in direct sun, but the old leather looks so great in bright sun)
Shiftless
East Bay SFO
I love the looks of those leather handles. I've never picked up a hammer or hatchet with them in place though. Do they function well also?
I’ll leave that question up to the guys who swing a hammer all day long. That Estwing I rehabbed has a nice balance and the feel of the shaped handle fits my hand quite nicely.
ctuai
Des Moines, IA
My first chasing hammer. Can't figure out the maker's mark. Any ideas?
Figured I'd post this planishing hammer as I got it from the same estate sale. The one above came out of the house and cost $3. The one below came out of a shed and was just part of the pile.
Are the 4 dots just part of the forging process or are they maker's marks? It's hard to tell, but it has a grey/blue hammered paint finish, which I don't want to wire brush off. I'm also hesitant on dropping it into the evaporust as I'm not sure what it will do to end grain of the handle. Thoughts on knocking off the rust?
LesserSon
PA USA
The planishing hammer has “MANY” under the mark, so made in Germany for the English-speaking market. I know nothing about German manufacturers.
Does the second hammer have the same marks on both sides of the head? If so, they may be from being held in a vise.
Putting wood in a water solution like Evaporust will swell the grain, damage the finish. I don’t think it would damage the wood itself, but it may pop the paint off the steel, which is what you’re trying to avoid by not wire brushing it.
I would not hesitate to wire brush it (outdoors & wear a mask - probably lead paint), then apply a thinned coat of BLO. If you are really into the color, repaint. Paint is just paint, after all.
Jr5
Not sure if I’ve shown it before… Starrett 815
5oz I think?
2oolhound
BC Canada
The chasing hammer is nice. I like the way both ends tilt downward to match the swing arc of the user. I've never seen a ball end set so low on the hammer profile before, they're usually more centered. I'm pretty sure I have that logo on a tool or two, I'll try to look for them.
I think the mark on your Planishing hammer is a maker's mark. At the very bottom below the 4 dots is what looks like horizontal wings or a similar pattern. It looks like there may be other details in there.
Mike'smeatshop
Found three of these old Tack Hammers at the FILs today. Can someone explain how the split is used in these hammers? I have looked it up but I just don't see it. Thanks.DSCF6779.JPGDSCF6781.JPGDSCF6780.JPG
O
The split end is magnetized which allows the user to easily pick up small upholstery tacks and safely start them without risking any fingers. The magnetic end is split to create both north and south poles in the same half of the head which enables the tack to be held in the center of the magnetized face more securely.
But I have a brass head tack hammer with steel faces, one magnetic that works fine? :dunno:
Mike'smeatshop
Thanks Outlaw. Out of the 3 hammers, none of them are magnetized. But could you place a tack in the slot and let the tip of the tack stick out to start the tack?
Not likely to stick in the wood, would take so much force to dislodge.
Danger, a tired mind thinking aloud here: Wonder if you can magnetize w a DC source and coils of wire, then reverse the poles for the other face.
Mike'smeatshop
If it was done at one time, I would think of magnetizing a second time. They re mag a lot of flywheels magnets.
2oolhound
BC Canada
How come the head only looks like it goes only 1/2 way through the head?
I remember from science class that if you slam a magnet onto the floor or other hard surface you can de-magnetize it. Not a great scenario for a hammer. Guess that's why it's called a "tack" hammer, you're only supposed to tack with it.
Mike'smeatshop
I don't know shaggy. Skooby dooby doo.
Rehandled, poorly?
I always assumed you start on one end, then flip it over to drive it home. Of course, with a really tiny tack, it may not give you time, or a need to hit it too hard.
O
The guys I worked with that had decades of experience could rap the tack in with one stroke and accurately too. Me, I had to start them carefully and flip and finish. But I was part time and my main job was PU and delivery of the furniture.
These days when I do that sort if thing I use needle noes piers to get the on posiotn sadn two taps and done; a solid start rap adn another to finish. Same with tiny brads.
Picked up this Hibbard Spencer Bartlett & Co. "Our Very Best" 8-ozer at the flea this morning. It's a shame half the logo is worn.
O
Nice find Lugz! I'd ben the stamp was held off angle. I doubt wear or at least not a lot from wear.
I did a wire wrap to this BP hammer handle post gluing a small crack starting, and the Stanley is an ongoing lemon oil job, trying to restore some resilience into the dried handle before my daughter takes it over:
I just noticed the File tracks on this handle, after the pic, it has them in several places, so someone did a hack job smoothing some rough spots is my guess. I like the patina on this for the most part. I did pop that glop of glue off later however
bb29510
that first hammer is for driving pins, you hit it with another hammer
