dolfans
Just wondering what is the difference and what are they used for the best and worst jobs? Thanks
Drill driver just spins. Good for general drilling and some screwing applications. Hammer drill has the same functions as a drill/driver plus the addition of a mode that both spins and hammers. This is good for drilling in masonry and concrete. The impact driver just spins, put it spins I'm sharp impacts that allows you to drive a screw without twisting your arm. It is the best for driving screws and threaded fasteners and can be used for some minor drilling.
Get yourself a combo kit that includes both an impact driver and a hammer drill. Plenty of them on sale this weekend. If you head over to toolguyd.com they have pretty well layed out some of the best deals on them.Thanks. I am going to build a storage shed after the holidays and thinking,planning etc on the items i need. So which one would i need? I have a drill that is a B and D electric and will buy a battery operated one soon
These days with combo sets so plentiful and cheap, get yourself a cordless drill and impact driver. Home Depot has a basic Ryobi set on sale for $100 with drill and impact. Crazy cheap, and Ryobi is a pretty good brand if you're just doing weekend work around the house.
Impact driver is for screwing, or can be used with sockets for working on cars and the like. Once you get used to using an impact driver for screwing in screws, you'll never want to use a drill for it. Impact drivers are much handier and easier to use. They're typically lighter, more compact also.
Its also pretty handy if you have to pre-drill holes for your screws to have both an impact and a drill, you can keep the drill bit in the drill and the phillips tip in the impact driver. Not having to switch the bit around really speeds things up.
Hammer drills are nice but they usually drive the cost up in cordless combo kits. If you routinely are drilling in crete and masonry, then they are a good idea. With hex shank drill bits, I basically only use my cordless drill to mix thin set or drywall mud. I have used it in a pinch to drill brick but it was not optimal.
If you forsee a lot of concrete/masonry drilling, probably a better idea to get a corded sds, you can usually find them used for a decent price. These you can use as a hammer drill or a mini jackhammer.
If you are drilling holes in concrete all day, then use the proper SDS hammer drill, but for homeowner use, a drill/hammer drill is fine. Might depend on the brand and how sharp you carbide bit is. My Makita XPH07 easily goes through concrete in hammer mode.This - those stupid hammering functions they put on cordless drills are useless.
drill/driver - Some drills do not have a hammer drill setting. We all used to drive screws with these before impact drivers were invented. Fine if all you want to do is drill holes.
I never said that.Really? So since impact drivers were made all drill/ drivers lost the capability to put screws in?
If you need to drill a hole in concrete - get an SDS hammer.
Now an impactor is a totally different tool and in my opinion, the most useful cordless tool you can buy.
Really? So since impact drivers were made all drill/ drivers lost the capability to put screws in? Worst advice in this thread.
All you need is a good drill/driver and if you want to spend the money you can get the combo with the impact driver. I have multiple of each and trust me if you going to build 1 shed and then use it around the house after you don't need to spend the money on both. Impact drivers are a pain to drill holes with since you are required to get bits with a hex shank so you almost need both if you want the hex driver.
Actually they are very useful, but they are not for drilling holes in concrete. They are more for drilling in brick, block and other masonry items where an SDS rotary hammer will chip and break them and where a regular drill won't get through them.
If it hasn't been said clearly -
A drill driver is a drill... people used them to also drive screws for decades. Drills became "drill/drivers" after the impact drivers became popular.. its to help label the tools that "yes, you can still install a screw with this"
How little experience you have with all of this shows big time.
