Teikas Dad
I'm trying to decide where to mount my Hot Dawg heater in my shop. Shop is 20' X 20' square. My original plan was to hang it centered on one of the two outside walls (other two walls are insulated and against an existing barn which is also insulated.). With the heater facing the center of the shop I was wondering about cold areas on the edges, so I came up with Plan B...hang it in a corner facing the center of the shop. I figured I'd get a better heat spread that way.
I know I can get a 45 degree elbow for the vent pipe so that's not an issue. I'm just trying to figure out the best way to mount it to the ceiling. Ceiling is 5/8" drywall attached to 24" OC trusses (with R30 insulation).
Do I go with a couple of Unistruts across the trusses at 45 degree angles, or mount a piece of 3/4" plywood to the ceiling and attach it to that, or what?
Looking for some ideas or suggestions based on what some of you have done. If anyone has any photos, those would be greatly appreciated.
