quicknova
So I couldn't find anyone that has done this on the internet but here is a harbor freight 72" with the side lockers / cabinets. Unfortunately all the attachments are designed around the 44" box but since they use a rather standard mounting I think they all will work with any combination of boxes etc.
As far as using these on the 72, they hang like normal on the lip of the box and you can use 1 of the pre-drilled holes that the handle would normally be on, the other hole doesn't line up so you could drill and thread it but unless your putting a ton of weight in it I think its fine.
