I was thinking of the h. Freight drill press yes no ? For light and occasional work:rocker:
D Dansdad Active member Joined Jun 29, 2013 Messages 37 Location concord,ca Sep 18, 2013 #1 I was thinking of the h. Freight drill press yes no ? For light and occasional work
K krdiesel03 Well-known member Joined Jul 7, 2013 Messages 317 Location Farmington NM Sep 18, 2013 #2 You can get a delta for $150
H Hootbro Well-known member Joined Dec 8, 2011 Messages 1,465 Location Delaware Sep 18, 2013 #3 The thing with the cheapie HF models is that you need to be able to inspect the spindle/quill for run out to make sure it is tight and not wobbly.
T TAMPAGT07 Well-known member Joined Feb 20, 2008 Messages 11,147 Location Palm Harbor, Fl Sep 18, 2013 #4 I'd go with a good quality used one instead.....
R rsanter Well-known member Joined Dec 22, 2007 Messages 18,492 Location visalia ca Sep 18, 2013 #5 They must hold their value very well.....every time I see one on craigslist the person want new price for them... Get a good used vintage one, way better Bob
5 53 hemi Well-known member Joined Aug 27, 2010 Messages 62 Sep 18, 2013 #6 When I needed a drill press, I didn't have the time to wait for a good used one to pop up. After lots of debate I bought this: http://www.harborfreight.com/garage...ss/12-speed-bench-drill-press-60237-8909.html I've worked it pretty hard for about a year now and aside from the handles loosening up I haven't had a single issue.
V Vegaman_Dan Well-known member Joined Jun 1, 2012 Messages 2,453 Location Pacific, WA Sep 19, 2013 #7 53 hemi said: I've worked it pretty hard for about a year now and aside from the handles loosening up I haven't had a single issue. Click to expand... Teflon plumber's tape on the threads of the handles where they screw into the mount will take care of those loose handles readily. Easy and quick to do.
O oldldh Well-known member Joined May 22, 2012 Messages 3,700 Location Fairhope, AL Sep 19, 2013 #8 I've got one of the HF drill presses, and so far, it's poked a hole in everything I've needed holes... Not going to lie to you, I'd have rather found a used Craftsman/Rockwell/Clausing/etc to restore, but there weren't any on offer, at the time... Still, I can't say that they're not worth what Harbor Freight is charging for them... Decent...not great...but decent...
5 57JoeFoMoPar Well-known member Joined Jul 21, 2010 Messages 194 Location S. Plainfield, NJ Sep 19, 2013 #9 Good used drill presses fall off of trees around here. No reason to buy junk when you can get a real quality used one for much less.
