I did see they are rates pretty good. I just wanted to get some opinions from here. I'm always just a bit skeptical of product reviews on a company's own website. Never know if they are censoring a bunch of negative reviews.I'm thinking about one, but I have a heavier Ford yard tractor, so I wanted to lift the front end with the engine hoist and scales, to see how much is being lifted, since the unit is limited to 300#.
They get high customer ratings, based on a large number of entries.
Yeah it would likely only be used sparingly. Oil changes, blade sharpening, etc. I just like the convenience of it, roll it over, few pumps of the foot, set the safety, done.Simple in design, but I sure wouldn't trust my life with anything from HF. Make sure you put some jack stands underneath before you climb under it. Even a couple hundred pound lawn mower will do some serious damage landing directly on your skull.
Further more, how often are you going to use something like this? As a homeowner, even if you used the lift every time you used the mower, that's only a few times a month. The rest of the time and year it's wasted storage space. As a landscaper, I use a floor jack with jack stands or I use my loading ramps to drive machine up partially if/when I need to lube, change/sharpen blades, clean out under deck, etc....
So do you use jack stands with it or do you feel safe with the lock pin?I have used it for three years and it works fine. I would never get under something without Jack stands or a lock pin which is provided. It won't lift anything to heavy but it handles my zero turn just fine. I use it every time I mow
Sent from my SM-G920V using Tapatalk
It folds flat with the removal of a bolt. That is the good news. Read my post for the bad news.Yeah it would likely only be used sparingly. Oil changes, blade sharpening, etc. I just like the convenience of it, roll it over, few pumps of the foot, set the safety, done.
I do understand the argument about storage space. Will have to consider that.
HF does publish the poor reviews, I have posted several. When I look at the reviews I re-align them with the worst reviews first. After reading a dozen I decide if I want to read any of the more positive reviews.I did see they are rates pretty good. I just wanted to get some opinions from here. I'm always just a bit skeptical of product reviews on a company's own website. Never know if they are censoring a bunch of negative reviews.
After reading many bad reviews, on an item, I will find 4 and a half stars. How does that work? Almost anything you buy can turn into a repair project. It is pretty scary to find class 4 nuts and bolts on a jack that is holding a tractor you plan to crawl under. There are no spares for anything under $400. Whatever warranty the product has gets you an exchange. How would you like to have to drag the several hundred pound 44" tool cabinet back for a replacement, because a drawer slide broke? Lack of product support is a major factor in the low prices, along with the switch to ever cheaper suppliers. Now it is India. I have some of their stuff that has worked out quite well but I try to be very careful about what I buy and I still get burned sometimes. I always look for a more reputable source at a price that is not outrageously higher before shopping there. In some cases, like the rolling stool, their junk is the same as the competition, but for less, so I buy theirs along with a free flashlight.HF does publish the poor reviews, I have posted several. When I look at the reviews I re-align them with the worst reviews first. After reading a dozen I decide if I want to read any of the more positive reviews.
Note well that SOME people will post a poor review based on nothing more than a tear in the shipping carton or a sag in the paint job. Another big item in poor reviews is the lousy instructions that accompany almost everything from HF.
One that I have found is the poor quality of nuts and bolts included. For me, if the specific item is okay and a good price I will gladly substitute better nuts and bolts and still wind up with a less expensive tool than if I had gone elsewhere. I bought two of the cheaper four-legged grinder stands and the bolts would stretch before they tightened. Replacing ONLY the bolts gave me some very good (in my opinion) stands.
