american lockpicker
The manufacturing base provides quality jobs that can provide good quality of living. Not everyone can be a service industry worker if this country is going to prosper.
I agree 100%.
Someone should have picked up on it because I was asking for a mod to delete most of the thread, it was late and I was trolling, but let me address a few points you guys made.The rental cost for a one time job is cheaper than that $79 harbor freight drill. And you wouldn't have a weak sister of the poor drill for the job either...More use than that? Well, I would just buy a decent product then because I would feel it was worth it. I could get a used rotohammer for less than $100.
No, I don't support HF jobs because those are worthless jobs that don't grow the economy or support a quality standard of living.
Sorry, Hi ball said "just blame the unions" in the post right above it, so I did. I tried showing sarcasm with italics. Dont get me wrong though, Im in no way pro-union and feel for the most part in certain fields they do more harm than good. I like what they have done as far as making working enviroments safer for the people employed in dangerous careers.So American works shouldn't get paid well and have good working conditions?![]()
Employees should get paid what the market will handle, paying a factory line worker $30+/hour to screw a few bolts in is not substainable and in recent years we have suffered the consequences.....It makes me Sad Inside Ah.. Hell blame the Unions.
Thats what a lot of people tend to forget or not realize, Its not just the retail jobs at the store. Its the ship guys, dock guys, train guys, truck guys that also make a living hauling this **** aroundThats simply not the case. You are still pumping money into the US economy, Whether its the Container Trains i Haul across the midwest to the Truck drivers whom deliver them to the store and the Employees who unload them. .
Its sad to say, but not everyone can work manufacturing job either, Some people are just too stupid and lazy to do anything more than flip burgers or run a cash register. Now Im not saying everyone that does those jobs is stupid or lazy, so dont take it that way. And at the end of the day we still need someone to do those service jobs.The manufacturing base provides quality jobs that can provide good quality of living. Not everyone can be a service industry worker if this country is going to prosper.
If this thread is still about the HF SDS drill I have an actual question about it.
Do these SDS rotary drills typically only have a single speed? The HF drill only has one speed, regardless of how hard you depress the trigger. I'm guessing it's less than 1000 rpm, but I'm not sure.
Do the more expensive brands have variable speed?
I would rather hire a PROFESSIONAL with HF tools and the talent to do a good job than some DOUCHEBAG with expensive tools that can't do the job properly! JMO.
I wonder if I got a dud?
Ordered one last night.
This discussion is easily summed up as follows: MrMark is an ignorant (_!_)
Necro Bugmenot, fools.
Fair warning: necropost
This thread comes up as one of the front page google hits for "rotary hammer bosch vs harbor freight"
I have had a 1-1/8" harbor freight rotary hammer for about 6 years, it has drilled about a thousand holes 1/2, 5/8, or 3/4 and was used for about 10 straight hours busting up concrete curbing for brick column footings (diamond saw cut edge w/ angle grinder, drill holes, bust up w/ chisel, repeat).
I've recently moved into doing more gate and fence work, so my need for drilling holes, possibly large ones, in concrete is increasing. I drilled a 1"x12" hole through a concrete stem wall with it this week, and were it not for the 3/8" plate I ran into 4" in, it would've been a sub 4 minute hole. It had no problem drilling 3/4" holes through rebar for the 2-post lift anchors with a good bosch bit. I will add that the HF carbide drill bits that I bought with it 6 years ago still cut, haven't broken one and they did all the work on the 12 brick column footing demo, but I did break the chisel.
And now to the reason I'm bringing this rotten corpse of a thread back, despite the 7 pages of douchebaggery in the middle of the thread. I burnt up the small(and useless) harbor freight corded 'hammer drill' using a holesaw to cut through the 3/8 plate in said hole, which got me thinking about the big hammer drill and what I'm going to do when it finally kicks the bucket. I kick the living **** out of it because it's a cheap tool, but it has tons of power and never seems to break a sweat, even under extended use (ie a 10 hour day of two guys passing it back and forth breaking up concrete). That said, I like quality tools and my general outlook on harbor freight is buy their best version of whatever tool to see if that's the correct tool for the job I need, use it until it dies, and buy a real one. So, I set about trying to find an equivalent bosch tool.
The current production HF hammer has listed impact energy of 3.7 ft-lbs, 10 amp listed draw, it's still $90 with no coupon.
The Bosch RH328VC is listed at 2.8 ft lbs , 8 amp listed draw , and $250
The Bosch RH432VCQ is listed at 3.1 ft lbs, 8.5A, and $400
THe 432 appears to be the largest hammer Bosch offers in SDS-plus.
I assume that the harbor freight hammer is over-rated, probably as much as 25%, which puts it down with the 328VC. At the same time, it draws more current than both the Bosch models and the one I have is certainly not lacking for power, drilling or chipping. It doesn't have enough nuts to effectively break concrete IE busting up sidewalk, but it's great for chipping and is really too much for brick/block.
So... seeing that, I have a real hard time justifying taking the plunge on a $400 unit that, on paper, doesn't put out the same impact as a $90 unit, especially considering that HF has come out with an SDS-max unit for $130 that outputs 6.6 ft lbs (10.5a) and the nearest bosch to it (11264EVS, 6.5ft lbs, 13A, $550)(RH745, 7.6 ft lbs,13.5A, $730)
Long story short, I'm thinking of buying one of the smaller bosch rotary hammer/ hammer drill combinations (11255VSR, 2.0 ft lbs, 8A, $200) that has a drill-only mode for small anchors and tap-cons and the SDS-max HF unit when my current HF unit craps out. Soliciting opinions of anyone who has used any of these models, especially the 11255VSR and either current production HF drill, and especially someone who has a nice company drill and a HF at home who can actually compare.
Thank you, no.
how could you have not had a SDS plus roto hammer before this?
And why not spend the 240 on a decent Bosch model?
Instead of junk that will let you down at the worst possible time.
I never understand the philosophy of buyng cheap tools. Even with the odd ball tool you think you are only going to use once it never works out that way.
If I hired someone and they showed up with HF tools I would send them home. Shows me they are either not serious about their profession or not successful enough to afford quality tools.
A homeowner with a HF tool is one thing, a working man with one is quite another . ..
