I am looking for something like this
http://www.directindustry.com/prod/p...ct-item_967835
However, instead of a one size fits all and you slip on a socket (like above). I am looking for one that you can slip into a wrench and it’s already sort of a built in socket if that makes sense. (14mm hex on one end and 14mm socket end on the other, and it will slip into the 14mm wrench you are using)
Like for example a 14mm will "plug" into a 14mm wrench and you now have a super thin 14mm ratchet, (Even thinner then the ones I mentioned above) but now have a little more lip than just a plain ole wrench. (So you need one for each size you want)
Has anyone seen these before? I know they sell them because I seen Craftsman has a set, but I just can’t find them anymore.
Thanks, Tom
Thanks, Tom
