Above 1200 Sq/FT Harley Jim's place
H
harley jim
Cleveland Tn..........out in the sticks
I had to go get the tractor and move the welder to the main shop then I spent about an hour squaring the frame so I could start building the roof. I cut a post 9'6" and made a bracket to support the center for layout purposes.
Then I had to go to the lodge and measure the seating, we are getting new benches and I had to get a count.
Came back to powder coat and Donnie was working on an insert for another set of handrails I am going to start soon.
Then I had to start the Ford and charge the battery a little bit
Squared up and ready for the top
Getting rid of the theater seats and installing church pews
We need to add something to the bottom
Got the Ford warmed up
It wont be long now
Sent from my SM-A102U using The Garage Journal mobile app
H
harley jim
I started out with a warm up project this morning. The spray tank on my mower works great except I'm getting to stiff to hook and unhook trailers, the ball is just too far under the tank for me to reach. I took the tank off and made a class three style hitch for the tractor. Later I will modify the tank to fit the reciever but for now I can hook up pain free.
I started with a pile of stuff I gathered this morning
I had some 3/16" plate and cut out the parts I needed.
One flat plate bolted to the frame and one triangle plate bolted to the hitch plate.
I welded a stud to the triangle it will bolt through the original hitch hole.
I cut down this tube and the receiver head. The receiver and plates were welded together and all sharp edges were smoothed out unfortunately that pic disappeared.
I took it to powder coat at around 1:00 and Dalton brought it back at 5:00 when he got off work.
It came out nice
Finished this and now to the gazebo
H
harley jim
I started by making a couple of brackets that I thought would help locate the roof rails but figured out that the drops from the roof rails worked just as well.
Brackets made from scrap
I squared and clamped four 20' rails and cut them at 9' then cut the drops to 9' giving me eight 9' pieces
I put some marks on the end to help align the rails during installation.
I used a parts stand and attached a rail to it with a square plate welded to the top set at 9'6" to use as a center point.
After tacking two rails together they were clamped to the square plate on top of the pole
Now I can get each corner close by looking up and adjusting to the numbers. Final measurements will be with a proper ruler. Now I need to make some inserts to weld the rails to but that will be tomorrow.
H
harley jim
I got sidetracked today, the bil was going to bring his truck over it has 350,000 miles on it and it has issues, he thinks I can fix it. So I started taking my blast cabinet apart as it needs a tune up. I bought the new parts and they showed up last week. When I took the glass out it did not have a seal under it, that's why it leaked so bad.
Now I know why it leaks
I made up two of these lights I put slight offset bends in the brackets and taped the sockets completely with electrical tape.
I taped the bulbs to the sockets to keep sand out.
Used the heat gun to form an exhaust tip for the fan
Put a screen in to keep the bugs out
Got a fan out of a bathroom exhaust to pipe the dust outside.
That's as far as I got today the bil showed up and ruined my shop time.
H
harley jim
Ok I played hookie from the shop for most of the day, I went back to one of the estate sales that I went to on sunday. On Monday they discount everything 70% so I went back and picked up a few things.
They were 8 and 9 dollars each
The two Nylant trucks were new in there boxes.
I had two like these when I was around six.
I got this for Pat, it will be yellow
I got it stripped and sanded, need to get some daisy yellow paint tomorrow.
shortykorte
Tallahassee, Fl
Nice additions. The dump truck needs to be painted up like yours.
For paint and body, I need to switch to those size so I can get the project completed.
BuffettFan
Central Illinois
Nice score on the trucks Jim!
All mine got donated to a family from church when I quit playing with them.
Wish I still had them, but don't know where I'd put them!
mybigwarwagon
Vale, Nc
I wish they still make quality toys. Heath can destroy a plastic truck in a day. He still has my first Tonka truck though.
H
harley jim
Shorty
The big dump and the loader will get painted and I am going to R/C them also, I've got some 12 volt dewalt drills and some old R/C stuff saved up for that.
Terry
My Dad had a big heart and thought everyone else was worse off than we were, He gave everything away, some stuff I wasn't done with. I got a giant tonka set for christmas one year I think it had six pieces in it and in the spring we got two dump truck loads of dirt dropped in the back of our yard, it became the spot to be in our neighborhood. No regrets I wouldn't change a thing.
Uncle Willie
I have Estatesales.net on my email (it should be in your app store) they send me a list every thursday. I saw these trucks friday they were 30 and 35 dollars each, Monday they were 70% off so around 9 dollars each. The guy had about 75 trucks on a built in shelving unit in his basement and about 20 more in a box that he was using for parts. It was hard for me not to make an offer for the lot. But I resisted.
I also got this CJ5 that I am painting to match Pat's CJ5
Pat's 73 CJ5
H
harley jim
I got some of the blast cabinet finished today
The motor assembly is done
I got this aluminum cake cover at a sale for 25 cents it will make a great filter cover
First I cut it down to fit the filter
Then I drilled some holes in the bottom, I added three screws through the front to help center the filter. Then an old air cleaner bolt to hold everything in place.
Installed over the vacuum port that was in the side already.
Then I used an old shop vac. hose to go from the cabinet to the exhaust fan.
I added an outlet to the switch that was on the cabinet and plugged the exhaust fan into it. Now when I turn the lights on the fan comes on. Next I'll add an alexa plug to it and it will be voice activated.
don long
southern california
Boy Jim
I wish we lived closer, we could have some real fun together.
You have some great imagination with all the improvements you are making around your shop. I like Pat's Jeep. You should keep that one you are painting. That way you and Pat would both have a Jeep.
Ben Buck
S. W. Ohio
Jim, looking good on the blast cabinet.
On the door I used gorilla tape to close up those dents- keeps sand from falling out when opened.
Love those old toy items also !
BuffettFan
Central Illinois
Jim, that's too cool about the dirt pile!
We had a small above ground pool till I was about 7 or 8, then it went away and we had about a 20' square sandbox where it had been.
The neighborhood kids and I had quite the earthmoving operation going on there!
Ben Buck
S. W. Ohio
^ Not to hi jack the thread.
Terry- Menards has freezers in stock- chest type.
This is if you have one in your area ?
Just sayin
PelicanPines
I buy real upright deep freezers... the kind you have to defrost... freezer burn is non existent. Only issue is the cooling elements are in the shelves. You can't remove or adjust the heights... requiring full butchering of item before housing it in the freezer.
I measure each shelf and go to the container store for plastic bins... really speeds organization and labelling of frozen meat, veggies, etc
Strouty
Southern Maine
I haven't been keeping up, will have to sit down and take a break to catch up, last few pages look like you have been productive though. ;)
shopnut
Florida
I saw your '98 GMC and was reminded of my '92 Chevy Sport 4x4. With a 350, 5-speed stick. Sold it after 11 years with 60K on it... the proverbial cream puff. Its nice to see those trucks are gaining popularity and value lately
mybigwarwagon
Vale, Nc
That is sweet
