Hello everyone,
back in time before "electric" cordless drills...
HAZET 2135 hand drill (1950-1988)
my current collection of HAZET hand drills as used in the large tool cabinet "101" from 1950 to 1979.
The hand drill was available individually as "2135" from 1958 to 1988 in HAZET catalogues.
The origin of the hand drill was the Arnz FLOTT GmbH machine tools company, less than 3 km (1.8 miles) away from HAZET.
There are also other manufacturers of similar hand drills, but the details differ from those in the HAZET catalogues.
You can find FLOTT hand drills with labels from other well-known brands.
These hand drills have 2 speeds - simply swap the hand crank and fixed handle to the opposite side.
However, FLOTT is better known for its large, electric drill presses till today.
Hazet 2135 (1950-1965? or only 1958-1965)
black, approx. 420 mm (16.5") long with drill chuck, 2300 g (5 lb), fixed front handle mount isolated from the gear housing, both gear covers each with 2 hemispherical slotted screws, crank with bend and fixed with flat-head slotted screw, shoulder holder fixed with identical flat-head slotted screw on side of the rod, wooden handles glazed dark brown, knurled drill chuck.
HAZET 2135 (1969-1976)
medium grey, approx. 440 mm (17.3") long with drill chuck, 2240 g (4.9 lb), fixed front handle mount integrated in gear housing, both gear covers each with 2 rounded Phillips screws, straight crank fixed with knurled screw, shoulder holder fixed with Phillips screw on shoulder side, wooden handles glazed red, knurled drill chuck.
HAZET 2135 (1979-1988)
light green hammer finish paint, approx. 340 mm (13.3") long with drill chuck (without approx. 305 as in the catalogue), 1290 g (2.8 lb), fixed front handle mount isolated from the gear housing, both gear covers each with 2 rounded Phillips screws, straight crank fixed with nut, shoulder holder fixed, wooden handles painted opaque red and modern design, in 2 rows knurled drill chuck.
My knowledge comes only from the HAZET online catalogs and observations of classified ads.
Maybe someone knows if there was a 4th version until 1958 or if it stayed the same until 1965?
There are no classic FLOTT catalogs online to check if there are more models that may fit to HAZET catalog pictures.
Or someone has pictures of other real HAZET hand drills.
Here is my listing with extracts from the HAZET catalogues:
(orange my real measurements)
regards,
