Head Shop Metallic Floor
benwah
Lakewood, Colorado
Hey all, just want to share some progress pics of a metallic floor I'm working on. This is about 1150 SQ FT of what used to be a orthodontist office turned bong shop in Gunnison, CO.
Started the process off with mastic removal (sorry no pics), then ground the floor with 60/80 diamonds.
1st prime coat was 100% solids epoxy tinted orangish-yellow and thinned 20% with solvent. Layed down this coat at roughly 250 SQ FT/Gallon.
2nd prime coat was 100% solids epoxy tinted with the main base metallic color (Sedona) and some accent (Silver), unthinned, roughly 250 SQ FT/Gallon.
The next day I screened the floor with 60 grit and 80 grit screens, to remove any debris. Vacuumed the floor and gave it a nice solvent wipe.
I poured the main body coat in 4, 4.875 Gallon batches totaling 19.5 gallons of metallic epoxy, or ~56 SQ FT/Gallon using the dirty pour technique. My ratios were 3 gallons of Sedona, 144 Ounces of Silver, 96 ounces of Violet per batch.
I poured these out in large blobs throughout the floor and spread with a Magic Trowel, then back rolled North to South then East to West, using an 18" 1/4" Epoxy Glide roller nap. After backrolling in an uneven pattern to not leave roller lines, each area was misted with denatured alcohol to lay out flat and add effects.
c93d9d436f5156f7aff2d960763a1be3.jpg842a503ef2311ef2de8c096b9a51baf9.jpg8c8984a366c140f8c5d85f89df57c566.jpg427d0c1067a2e9838ef0071f2c1fe50c.jpg0ea0d8effcd06add90345ccfa21d7428.jpg
benwah
Lakewood, Colorado
Wet epoxy41540c8c56ad03f07fe0bb6da1115422.jpge99292d0168f2b5ce35583c5194432e9.jpg6e03a84c2fe2b7dfb4d550dd5a6c4c90.jpg
benwah
Lakewood, Colorado
Cured epoxy. Today I am screening the floor with 100 grit screens to get it perfectly flat and we'll be applying a clear solvent-borne polyurethane with anti-slip aggeegate in it.011cc76cc070c9bd2f8fffe8aa08f68e.jpg551b848b85e919910af5ef916658258b.jpgbfb615c1f2e1be850ce993b33f730078.jpg047c7fee930e50a4681f57356c59db27.jpg30267dc8e8046d2c5c78ebeca5b5ca14.jpg0c1afde788639a8b9b8ddbe15c8cfcbe.jpg
benwah
Lakewood, Colorado
Final product. This is what the floor looks like now that it has 1 coat of satin polyurethane with 12oz of aluminum oxide per 1.5 gallon kit. Dust on the floor from me.
c5093a978b9db44d6dd74f4a7118ba6b.jpg44ffea0fc3022d4d2962813ffc41481d.jpg3db669606d3b39470d7ed95492e4b580.jpge4a2207511ecf631dc9e430bce931d8a.jpgbe93e8a44f7747faef0d96d147ef2ad8.jpg15335d3f7b1fb34b798189ee726772e6.jpg
benwah
Lakewood, Colorado
Thank you Armorpoxy and LXCam! Customer is beyond happy.
I actually had a few tiny drops where the poly foamed from being too thick. I scraped those areas off, mixed up a small batch of poly and added some of the Sedona metallic. I then reapplied using an artist brush. It blended in nicely and is not noticable. On to the next...
