sourdough
Not my problem but a problem for my BIL.
He has a Trane (don't know mod/ser #) that runs the condensing unit when the t-stat is set to "heat", but the condensing unit will not run when set to "cool". I suggested it might be a problem with the t-stat heat-off-cool switch.
He had an HVAC tech out today ($180 for the visit) that determined the t-stat is fine but it needs a new TXV.
I have done A/C work for years before retiring but have no experience with heat pumps. I know how they work in theory, swapping the condenser for the evaporator depending upon the mode.
Is there a separate TXV for the heating and cooling sides of the system?
Is there a separate liquid line solenoid valve for each side with a separate LPS?
He won't even let me look at it because he is convinced that the 5-ton 3-year-old unit needs an entire service inspection, even though one was performed 2 years ago when he bought the house. The heat pump (with aux electric heat for cold OSA temps) worked fine throughout the last winter.
I know all of you techs are going to want to know the nomenclature from the data plate, but I don't have it.
Opinions welcome.
Opinions welcome.
