Good Morning All!!
This one is going to be a little long...
My house has separate heat pumps for upstairs and downstairs. I replaced my downstairs unit about 6 years ago. A lot of info on that is in this thread: https://www.garagejournal.com/forum/threads/heat-pumps.383762/
Just to note, the Amana has been great, no issues, lower electric bills and it's so much more comfortable downstairs.
OK, so my upstairs heat pump hasn't worked well for years. I've had several HVAC companies out, but it's a cheap unit that was put in before I bought the house in '08. I don't use it for heat unless it's over 35 degrees or it doesn't heat and it couldn't keep up with A/C last summer. Unfortunately the owner retired from the company I used 6 years ago and sold it to another local company. I thought for sure that the son would take over the business, but that didn't happen.
I had the company that bought them come out and give me a quote. They measured everything and did all of the normal checks, so I thought they seemed pretty good. The salesman came out the next day. He had 7 Levels of quotes with no real information. "Prestige", "Premier", "Elite", "Economy", etc... Didn't give brand names, model's, SEER, HSPF or anything. It did list the warranty and talk about the MERV 16+ESA filters.
My upstairs is a good bit smaller than my downstairs, so the heatload calculated out to needing a 2 ton unit instead of 3 ton like downstairs. I don't need a new trunk for upstairs, don't need a humidifier added or anything else. The only thing that I asked for extra was to either enlarge the small return or add a 2nd return. I had a 2nd return added downstairs as well. After a lot of pressing, the middle of the line system they quoted was basically the same Amana unit as I have downstairs and that sounded great to me. Then the quote was north of $20k. I can see it if it were something crazy or hard to deal with, but it's about as straightforward as it gets. Air handler is right in the attic, it's a straight shot up stairs and then the opening goes right into a plywood covered attic to set the air handler. The outside unit is right behind my house and you can drive a truck right up to it. The salesman figured out quick that I've spent a lot of time around HVAC in the past and his game wasn't working. Nice guy, I talked to him for a while and he understood that I'm not paying $6k for the high end filter, replacing existing ductwork with the same size ductwork, etc that they planned to do.
I had a different company come yesterday to measure and check everything for a quote. I've saw this companies work before and all of the reviews I read are top notch. I spoke to him for a while and he's going to get me a few quotes later today. He's quoting a similar Amana Inverter, Lennox, Bosch, one I'm forgetting and he brought up GREE. He said they sell a lot of Gree Inverters and haven't had any trouble with them. I started reading about them last night and had no idea they were as large as they are and that they build parts for a lot of the big name companies. I'm not talking about putting in a mini split, I'm going with a ducted inverter setup. The Gree does use side outlet outdoor units that look like a large unit from a mini split, but the more I read the more I see companies going this route.
I'm not opposed to it, but was hoping to get some feedback from the masses here on Gree as well as anything else I should be looking at. Truthfully, I'm leaning toward Amana already because this one has treated me well, but not opposed to anything else.
