Heater for 1200 sq ft garage?
bad_idea
Pasquotank, NC
I have a 30x40x14 detached garage. Vinyl sided with shingled roof. OSB sheathing, 2x6 studs. No insulation or interior wall covering. I would like to heat it up to 60 or so while I am out there working. What do you all suggest? Thanks.
arkansawer
start with the carrier of your homeowners insurance. don't want to put the cart before the horse
Showkey
"MEMBER EMERITUS"
Wausau WI
It’s not a matter of luxury..........it’s more common sense or lighting $20 bills when your heating.
What they said...........would you try to heat or cool your home with no insulation ?
Rule number 1 when trying to condition the indoor air.........seal to control the air exchange rate and insulate !
If your set on not insulating........run a torpedo heater with the door open.
Bad00SS
Rockford, IL
I just did a 28 x32 last week and I bought the R13 bats for the walls for $260 from menards and the ceiling I had a company blow in the for $600. So for $860 I had a fully insulated shop. Just save a few paychecks to do that before you buy the heater. I feel like 6 months of running the furnace would pay that money back in savings.
But regardless I think an 80,000BTU ceiling hanger Mr. heater from menards for $500 would do it. I have the 50,000BTU In mine that's about $400. since i'm insulated it will cover 1,250sqft and i'm only 900.
Falcon67
Merkel, TX
Maybe best you can do for temp, unless you want to install something like a 45K or 60K gas/propane heater.
The Cobbler
your heat needs are totally different pre & post insulation, and different sized heaters required for proper performance. look at buying the heater sized for when you're insulated , and adding supplemental heat to that while you have no insulation .
bad_idea
Pasquotank, NC
Open trusses. With insulation comes sheetrock for the walls and tin for the ceiling. I do not want to install fiberglass batts with no sheetrock, I am concerned the craft paper would catch fire while I am welding.
My thought was a job site heater of some sort or a wood stove. I am sure I can scare up some free firewood somewhere if a wood stove would get some heat into the building in a decent amount of time.
