Heater yearly pre use?
Rogers954
Clearfield, UT
Hey guys so last year i got my Mr. Heater big maxx installed and running and what a difference that made for my winter workability in the shop. Anyway temps are dropping fast here in Utah and i know it won’t be long before it will be time to fire her up in the early mornings to get the shop up to a comfortable work space until that mid morning sun has a chance to catch up. So with that in mind what do you guys normally do before the first season use with your heaters? Anything i need to be looking at before i fire her up? I don’t remember seeing anything in the directions when i did the install so i figured I’d ask the experts who have been doing this for a while. Thanks fellas
strutaeng
Dallas, TX
Interested in this as well. I know there can be some issues with the little vacuum hose getting cobwebs, etc.
I turned mine on 2 times during the summer to make sure it fired up. Was planning on taking panel off and just giving a gentle blast of compressed air to remove any dust that I'm sure has made it's way into the control panel...
Page 12 of the manual also additional checks:
https://www.mrheater.com/downloads/dl/file/id/255/mr_heater_big_maxx_unit_heater_manual_2018.pdf
R
Rogers954
Clearfield, UT
Thanks for posting this up, i forgot there was burner inspections to be done each year, good info.
Kaizen
New England
All heaters of any type should be run before it gets cold in case you have issues and need a pro. Once that first freezing night happens it’s a three month wait
Jackfre
N CA
What does the manual say. A bit of compressed air around the ignitor and a vacuum for cleaning the cabinet/hx area should be sufficient. What does the manual say?
