i have a small blind hole in a turbochahrger that is stripped out. it holds the turbo oil tank in place. (bolt on each side hole in the middle hole for oil drain with a oring) the helicoil tap is tapered and the first few threads are for alignment. the hole itself is about as deep as the helicoil so i need every thread i can get.
is there a sti tap the has threads from the edge and will bottom out in the hole so i can get the helicoil installed? the tap in the kit only taps about half the hole and then the bolt binds in the hole since there arent enough threads to tighten the tank completly against the turbo itself causing a leak
8mmx1.25 thread pitch and bolt
