2ndGearRubber
That's why you have to carefully apply. If the break is jagged (good) the break itself would be taking the force, the CA just keeping it together to do so.
CA glue is also easily dissolved with acetone.
This sounds really interesting. So you just use the tiniest amount of the glue on the other piece, so it doesn't ooze out and stick to the copper, and then stick that piece onto the stuck section? Let try and give it a try?
I'll keep that in my back pocket. Sounds tough to get the glue application right though.
