Help choosing fasteners for wood retaining wall.
ive
Canada
Hi everyone.
I’m building a retaining wall near my little shop. I purchased some 6x6 pressure treated lumber. The wall will be about 5 timbers high.
The question I have is what should I use to fasten the ties to one another. I know that rebar is pounded down for the first row, but for the rows on top is it better I use galvanized spikes or timberLOK screws for the 6x6’s.
As always thank you for your time. It’s truly appreciated.
You need to concentrate more on foundation, drainage from behind the wall and "set back".
Personally, I would go with more rebar.
matt_i
I always think screws are better. The nails (spikes) are faster and cheaper but split the wood near the end grain and so there's less holding power.
SGKent
Citrus Heights CA
treated wood comes mostly treated for foundations unless you go to a large lumber yard and specify direct earth contact wood. That has so much arsenic in it you don't want the kids or dogs etc., around it. RR ties work but have lots of creosote in them. It is also hazardous but not like the arsenic treated wood.
mbatarga
GA
I've always using rebar for the first 1 or 2 levels, then long spikes for the uppers. Also - always pre-drill for both.
Are you planing on using any deadmen timbers for rigidity/stability?
walta
Dutzow Missouri
If you need /want the wall to last more than about 15 years consider the locking block walls.
I used the 12-14 inch nails had to pre drill.
Walta
Kaizen
New England
Screws by far. Big spikes have to be pre drilled. Lookup deadmen. You should install the in the last to the top.
As said above it will rot so I have changed to concrete block walls. About the same price and only downside is more lifting. Lasts decades
jkeyser14
(rural) Maryland
That is really old info. Arsenic hasn't been used in decades. What you need to look for is pressure treated lumber rated as "ground contact". These days most big box stores only carry ground contact treated lumber in order to reduce inventory sku's and prevent liability when home owners use the wrong thing. You have to go to specialty lumber yards to find non-ground contact lumber.
CraigStu
Blacksburg, Va
Yep, I just bought ground contact 2xs at Lowes. I didn't search because I wanted GC but I think all their PT is GC.
I
ive
Canada
Good thinking. This will be a garden.
I
ive
Canada
Gonna use as much rebar as I can.
I plan on using deadmen. Thank you.
I
ive
Canada
Walta
I was thinking of using blocks too. Rest of the family likes the wood look. Thanks for the idea.
I
ive
Canada
This is what I purchased. Thank you.
I
ive
Canada
Gentleman, now that I have decided to use the timberloks, what length should I use. The ties are 6x6
Thank you.
I
ive
Canada
Hi guys. Is 1/2” spade bit is good for drilling for 10mm rebar?
I
ive
Canada
Also, i ordered 10mm rebar because I had a friend who gets a discount. Should I just buy 1/2” rebar. I know the thickness isn’t that much, am I just over thinking?
Thanks!
Kaizen
New England
Thanks!
Yea all that’s needed. Make hole smaller then rebar so friction holds it together. Tiber lock should go into next one about half way. I tried the really long ones before and had them snap so just use what you need. 12”?
mike93lx
Richmond, VA
Thank you.
I used 8" for my 6x6 wall, but it is very low and has little pressure behind it.
For something larger 10" would be good.
I would recommend checking Amazon and look for warehouse deals on the various sizes. My last project with timberloks, I went 1/2" longer than I initially wanted and got a bucket for about half price doing this
Marctrees
TX/LA border - Toledo Bend
A big advantage of screws is no clearance hole is needed... as long as the unthreaded portion is long enough.
I used 400 GRK RSS 3/8" in a similar situation, w a plug in milwaukee drill went in like butter.
Marc
