Help choosing the correct breaker
Pontiac787
New Hampshire
Hi all,
I need to add a 220v 30amp breaker to my GE panel for a welder. Is it just a matter of finding a GE breaker with the correct specs or does GE have more than 1 style?
Here is a link to a possible match.
This is a photo of one already in the panel. The numbers are NP1578012-C and E11592S.
Thanks!
Norcal
There is GE THQP and THQL you can use either one is 1/2” wide and the other is 1” wide per pole , the space available for a 2 pole breaker for 240V is going to dictate what can be used.
Terry D
St. Louis, MO.
wyliesdiesels
Modesto, CA
Does your panel have a label on the inside cover? The compatable breakers should be listed there.
The newer style thin GE breakers have a different bus connection than the older style.
wyliesdiesels
Modesto, CA
IIRC the 1/2" thin breakers can only go in certain spots due to the way they connect to the bus but my memory is dim on GE panels because i do not work on them much.
