I have a bearing starting to go, I have tore into this and have removed all parts up to & including #30 )
I have the assembly #20 to #29 removed from the main body . I suspect bearing # 29 is bad. collar # 28 is threaded on to the shaft of the rotor #23 .
the only way I see to separate the rotor is to pull on housing # 21 . It is very close to the body #25 and quite fragile looking . I'm thinking a small puller and gently see if it will pull off the shaft of the rotor?
