Help finding bearings for bandsaw?
motorcitykid
Detroit River
I have a rare antique bandsaw that didn’t come with the guide bearings. I haven’t been able to find another like it to follow. It’s a 14” Childs&Co and I’d prefer to keep the original guides if possible so I need to get a bearing that will fit and perform well. Any ideas as to which to pick and where to buy from?
GeoBruin
Maybe I'm confused but that saw appears to have guides. The little rods that nearly touch the blade.
alfadan
Augusta, ks
I think it is supposed to be a ball bearing. You'll need to measure that stub more accurately to see if it truly is 5/8 .625" or 15mm and get a sealed bearing with that ID.
A 6202-5/8-2RS would be a likely choice I believe.
motorcitykid
Detroit River
Thank you, I’ll give that a shot.
motorcitykid
Detroit River
That age probably didn't use a ball bearing like modern saws. Based on the available space for it, I would think it's probably a bronze bushing with a 5/8" id.
After cleaning it a bit I believe you are right, but I don’t see how it will work. Thank you for the info
motorcitykid
Detroit River
Well, the nub that is in there is bronze. Which makes me think that it could be a bronze bushing. Worst case I have to buy a new set of guides and stash the OEM stuff.
motorcitykid
Detroit River
No, smooth. I removed it and cleaned it looking for some indication, but there's no grooves or threads. I believe it rides the bearing exactly like your picture, but will have to figure out how.
dutchgray
Dorset. England.
My Do-All uses a hardened steel disc with a post on the back that goes on a hole for the rear blade support pad.
Using ball bearings where the blade runs on the outer bearing race is actually a really poor way to do it, bearings are not designed to be used like that, they do it because bearings are cheap and available everywhere so the manufacturers don't have to keep stocks of guides on hand for spares.
motorcitykid
Detroit River
It’s just a bronze nub/bushing with nowhere to attack a snap ring etc. Not internally threaded.
whateg01
doo dah, kansas, usa
I think that might be right for this one too. I don't see any evidence of wear on the outside on the bronze part there. I wonder if anybody still makes those parts? Or is this a custom part now?
If it was my machine, I have the tools to make a new part as you described but for somebody else, I wonder if it is better to look at aftermarket upgrades for modern machines and ways to adapt them to this. For example, in this case, maybe a new post can be found that fits the hole the bronze part goes into but it's made to have a modern ball bearing bolted on.
motorcitykid
Detroit River
The parts would either be adapted from another machine or fabricated. I’m a novice at best, but my brother in law is a machinist and has all the equipment at his work to fabricate anything I could conjure up.
I think at the end of the day figuring out the original design is not nearly as valuable as making the making the machine run well so that I can get some time behind it to better understand how I’ll be using it most to decide which guide system/s would be most beneficial.
I just want a good base machine not necessarily doing heavy redrawing or tight turns.
I have all the glue removed from the wheels and cleaned, now to figure out which tires to use.
whateg01
If this isn't a restoration, I would go with my second suggestion of having your brother make something like this.
Eta: dead simple lathe job, but I would suggest, and he probably would too, adding a flat for the set screw to touch so it can't get stuck in the hole.
motorcitykid
Detroit River
Would a hardened steel wheel be a more effective solution seated on the bronze?
neophyte
Pennsylvannia
Carter Products manufactures bearing and other bandsaw guides for numerous bandsaw models, as replacements or upgrades.
I don’t know that they would have off the shelf guides that would fit, but if you can supply dimensions, maybe they would, or could supply something.
There are also ceramic guides for bandsaws used to reduce friction.
This place seems to offer a much wider range of products than I recall last time I checked their website several years ago.
You would probably have to supply dimensions.
seber
Deep East Tx.
Figure out the ID, OD and width. Then call a bearing house and ask for a conrad bearing with those dimensions. They can fix you up in a few minutes. Nice thing about bearings is that the specs don't change over the years. Any bearing book will give the same results, although foreign companies might have different numbers.
milkovich
Akron Ohio
I had a very early 1900's band saw (Durham I believe) and that's exactly what it used. It looked like an engine valve with a very short stem.
motorcitykid
Detroit River
I’ve been a little sidetracked trying to figure out a couple table saws. I reached out to Carter Products to see what they had to offer, and my brother in law is a machinist at Ford and said he could make some.
I haven’t come to a conclusion. I’m on the fence about urethane vs rubber tires and using a thrust bearing vs a bushing of some sort. Next few days I’ll get it handled.
motorcitykid
Detroit River
My Brother took the guides to FoMoCo and turned the bushing a bit so the bearing could be press fit, I’m excited to get it going. I did look at several different new guide systems but I want to try it as it was built first.
I picked up a Timberwolf blade from Suffolk and some Urethane acutrack tires from bandsaw blade warehouse on EBay. Now to build its stand and it should be good to get going.
motorcitykid
Detroit River
The bottom wheel wiggles a little bit but the top tracks true. Cuts like absolute butter, the rear blade guide is can be in the way, the front is bent. But it’s gonna work fine.
