Help Finding Swivel Casters for Williams Box
Joe Piro
South Carolina
Can you help me find a manufacturer for swivel casters to match those on my Williams rolling tool cabinet. I need to replace the stationary casters with swivel casters and would prefer to replace only two instead of four all the way around. Can you help me match the existing swivel casters from a third party maker? It looks like the current Williams casters don't match. Details are as follows:
I think I got a pretty good deal on a used Williams top and bottom chest for $300 for Bottom and $200 for top. It came from an industrial mill with a massive tool haul of used tools (including some big Snap-on wrenches).
Both top and bottom are pretty clean outside and very clean inside the drawers. However the room where I store my tools is so small that I cannot maneuver the box unless I have swivel casters all the way around. (Like most boxes it came with two straight and two swivel casters.)
The bottom box model number is C40-7RC which is not in the catalog, but it seems to be dimensionally identical to the updated W40RC7 in the recent catalog. The catalog lists a part number for the casters but photos look like cheap pressed parts compared to the casters I have (see photos).
The casters are welded and the parts seem to have been stamped from approximately 3/16 inch thick plate. The casters screw into captive nuts on the bottom corners. The bottom plate measure 4" x 4 1/2" and the bolt pattern is probably a square 2 3/4" by 3 1/4" (although I measured to the nearest 16 and its a little different)
Below are photos of: ==> the new model from the catalog, side, end, and bottom views of the existing casters, a sketch of the bolt pattern, a quick sketch showing the elevation estimated off the floor and the nameplate on this unit.
Thanks for any help!
  • Williams Box Catalog.pdf
jdm5
CT
Can't help on this specific caster, but can recommend "Caster City" - call them, they know their stuff and can help. https://www.castercity.com/ - I've used them a number of times for furniture and tool casters.
(no relationship to them beyond happy customer)
J
Joe Piro
South Carolina
Thank you... I spoke with Greg at Cater City and he made it as certain as possible that what I ordered would fit. I also spoke to the owner on Greg's day off and he said Greg had been with him a long time. They both definitely knew their stuff.
I now have two new swivel casters (and a swivel caster at every corner) and have achieved my goal of being able to maneuver the tool cart in a confined area. The elevation of the new casters is almost the same as the originals and if there is any slight difference I put the slightly shorter old casters on the back so the unit would tilt back rather than forward so drawers tend toward closing instead of opening. Any difference in height between new and old is mostly just due to old age (I'm shorter than I used to be too.). They made it easy to order online and delivery was quick.
Thanks for the advice jdm5.
Now I discovered I need drawer slides just for one drawer and if you have any useful information, that will be a new post.
Thanks again. I love this Williams top and bottom. It's reasonably well made, in good condition and it was a bargain IMHO.
