Help identifying jack stands
rg171352
I’m looking to replace my recalled harbor freight jack stands and found these for sale. Does anyone have any info on these? There is only a pair, but they look well built.
R
rg171352
Any idea of what sort of weight they will support? Thank you for your replies.
Bighead38
Rockland County NY
Number wise I’m not sure. If I don’t have them extended hlafway I put pickup trucks on them all the time. If I need more height I use a way bigger pair that I have.
Edit: I looked a Little closer and yours are actually nicer. The lock mechanism looks better.
driftpin
Am I the only one seeing scaling rust inside the angle-iron pieces on the ground? I don't suppose the wide middle piece on the ground is in such good-shape either, from the looks of it, though that may have less to-do with the weight-bearing of them than the perimeter pieces.
I don't think I'd be too-interested in stands that had active rusting that these apparently are showing. I recently returned my HFT jackstands for the $ refund, these look more-suspect to me than my nearly-new and rarely-used HFT pieces.
As to the manufacturer, often the cast lifting member has a name cast-into it. I'm sure that you gave them a good going-over. I have another pair of four-legged, veteran stands, they're cast and riveted, they served in a Miami FL gas station/service-repair shop for decades, and they were given to me. Old stands can still serve your uses, but those appear to be deteriorated more-than I would think is safe.
shannos
Warshington
Yes. You are the only one. And I would not be concerned in the least.
BTW. The HF jackstands were defective in manufacture. Looks had nothing to do with it.
whateg01
doo dah, kansas, usa
I wouldn't discount the rust altogether. The bottom side could be worse. The load bearing is partly a function of the perimeter keeping the legs from splaying outward, though having the post in the middle does most of it.
Dave
