Help identifying shelfing hardware for steel cabinet
Carter240
So I picked these steel cabinets up a couple years ago and they didn't come with any shelves. I can make the shelf but I am missing the little pegs that go in the walls of the cabinet though. Can anyone point me in the direction of where I could find these or what style they call them?
Best photo I have at the moment, I will get a better one if need be.
corvette43056
ohio
You should be able to go to lowes in the shelving section they will have different sized ones plastic to metal
Sent from my SM-N960U using Tapatalk
C
Carter240
CARTER: is there a brand name on your cabinet?
There is not unfortunately, I think I may have found a match at the link above though, but I will try Lowe's first. I thought maybe there was a name for this specific style or something. Thanks for the suggestions!
drivesitfar
Carter: while there are many many types of shelving brackets or supports the ones the Cobbler posted an Ebay link might be my first choice to fill your holes. those are metal and there are plastic versions, but i'd prefer metal cause might be a little heavier duty in case you might load up a shelf a bit on the heavy side.
good luck
C
Carter240
good luck
I agree they look very close, I will have to order some and see. Thanks for the help everyone
