Help me classify some old generation tools
rural22
AL
Is this some type of ratcheting device?20190405_140735.jpeg20190405_140748.jpeg20190405_140757.jpeg
retDAC
near Huntsville, Ala.
First item is a ratcheting adaptor (correct spelling). Used with beam type torque wrench, flex bar, sliding tee with extension, or wherever you want to add ratcheting capability.
R
rural22
AL
Thanks... after cleaning it I got it to ratchet properly.
R
rural22
AL
Thanks for the info. Most of my items came from the uncle of a wartime mechanic...
Stuart in MN
Minneapolis
If you're trying to figure out age, most of the Snap-On tools should have a date code on them, and there are charts available online that show what the date codes mean.
Kwikasfaki
Australia Vic Wodonga
"Ratcheting device" post #1,
I had one (3/8" drive) given to me, brand new, in about 1980. Never used it, EVER. In about 2010 I gave it to another bloke, also a mechanic, to this day he has not used it either! Well made very good quality, Sidchrome. About as much use as an ashtray on a motorbike.
R
rural22
AL
True...I have had it 10 years, it didn't ratchet, and not knowing what it was, never used it. But now that it works and I know what it is, I could have used it the other day when I used my breaker bar in a tight spot wrenching on my tractor. It is gimmicky, but -- ya gotta luv tools -- :)
The first "ratchet adaptor" was patented (1,428,840) by Eastern Machine Screw Corporation on Sep 12, 1922, for it's H&G combination wrench sets. It was an in-line design, way ahead of its time. 7/16 hex drive. There was no ratchet in the set. The first square drive “ratchet adaptor” (No. 6, with two open-geared, spring-loaded, clutch-switched halves) was patented a few months later, on January 20 1923, by one of those useless and gimmicky manufacturers - Snap-on. Snap-On’s first inline ratcheting adaptor (No. 67), was introduced in 1939.
A device that turns any static handle with a male drive stud (breaker, Ell/offset, etc) into a ratchet, doubling the handle's duty, but saving the space and weight of a redundant ratchet handle, may seem useless and gimmicky in 1980, or even now, but even now it has its purposes in carry kits and close quarters.
That extension with the dual band of knurling was probably introduced by New Britain around 1947. Here is mine in my 1/2” drive set.
R
rural22
AL
Ratcheting adapters have their place, more so in milwright work and construction than in automotive.
I used one a while back. I don't do much physical "work" at my job, as we contract most everything out. But, some things are a lot more simple than they look, and it makes sense to do them ourselves because the bid cost is disproportionate to the work.
I had a job like that on a bridge, that involved welding about 5 pounds of rod, and using a mag drill to drill 20 holes and insert 20 large diameter lag screws. The mag drill wouldn't drive the lag screws, it would just break our drive adapter. The force required to drive them with a ratchet was hard on your arms. So, grabbed a 1" drive breaker bar that was about 30" long, and an adapter to a Snap-on 1/2" drive ratcheting adapter. With the leverage, the job went well, if not quite easy.
As a home-use GJ member, I have a 1/2 Craftsman (USA) 18-20in long breaker bar and a 12in ratchet. In my younger days, I seldom used the breaker bar but just hunkered down on the 12in wrench when needed. As I become an age-advanced GJ member, I find myself using the longer bar more frequently with less hunkering down required. With the ratchet device, I now can ratchet-wrench with greater leverage. Hurray for my new use tool!!
