Help me Decode this Wiring
mossy
Bought our place a while back and there is a room in the barn/shed that had been partially wired but unfinished by the previous owner (now dead) and I've been wanting for years to just get some outlets in there so I can have power but there's an odd mix of 2 wire and 3 wire chaining the wall outlets together that I don't quite understand. And oddly the wiring never makes it to where the switches were intended. I just need some help understanding either what was intended or how to fix and finish. Appreciate any eyes on this. Attached is my diagram of the wiring I've identified. There's two loose coils of wire sitting outside the room that were fished into the wall and are found at the where I assume the switches would be, but aren't otherwise connected to anything. and in that same switch opening there are 3 more wires which go up into the ceiling, to three sets of ceiling lights - I assume they were intended to be lights, but they are also just open boxes with wires sticking out. It is all very confusing.
Norcal
Taking photos & posting them here is quite helpful, it may be better to rip it all out & start over, pics will tell.
mossy
I'm located in eastern iowa. The room drawn up is a room at the back of a larger metal shed. The metal shed is detached from the main house. Has its own panel some ways away from this room, with just a couple fuses in it that control outlets mounted to the outside of the panel and a garage door. There's room in the panel for more. The wires in my drawing labeled power 1 and power 2 are nothing more than loose wire sitting in the corner on the floor but has one end fished through the wall and comes out where the switches would be. I labeled them power 1 and 2 because it made the most sense they were intended to be run to the panel.
I attached some example photos. One is a section of wall panel I took down to see how wire was run. The black wire in the middle is 3 wire plus ground 14-3. the white wire running to the left and right is 2 wire. Also included a photo of what the typical outlets look like and the assumed switch box that has the power leads coming in.
dogdog
I wouldn’t sweat it too much?
Maybe the previous owner wanted some 240vw With neutral there for those. 3 wireds. If you don’t then just cap the red and hook up as normal.
walta
Dutzow Missouri
To my way of thinking what is currently in place is irrelevant.
Decide what YOUR wants and needs are. If something happens to be already in place, that is great but get what you need not what someone else planed.
Where do you want switches for what lights?
240 volt outlets?
120 volt outlets?
Door openers?
Outdoor lights & outlets?
Walta
