Hey everybody. I’m currently working on putting new spindle bearings in an atlas Clausing tool post grinder. I was able to get the old bearings out and I found that they were labeled as Norma 9012 DD. I found that Clausing calls this part 044-004 in the old manual, and supposedly this was replaced by part 044-058. I need to find a replacement for this bearing.
I was able to precisely measure the bearings with micrometers. Here are my findings.
32mm (1.260in) outside diameter
12mm (.472in) inside diameter
12.7mm (.500in) width
Based on my research this seems to be an odd size. I found online were somebody referenced part 044-004 as 10mm wide, not 12.7mm. I’m almost curious if someone put the wrong bearing in the spindle at some point in time. I assume this grinder is over 60 years old so anything could’ve happened.
Any help is appreciated. Thanks in advance.
