Help me pick a flooring color
slomaro3.4
SW Pennsylvania
Found an installer I liked now I’m just figuring out what flake colors I want for my floor. Any design opinions? Being near Pittsburgh I like the steel city one, but is that too busy with OSB walls? He is using Torginol colors.
S
slomaro3.4
SW Pennsylvania
Also if anyone has advice, since I've already mounted my maxjax, do I:
1. remove the posts and tape over the holes or fill them with cotton balls or something (leaning this way)
2. leave posts in place and epoxy around
Overboost44
MD
You have my FJ in your garage. Good taste in cars, not so fond of the floor if you are doing work in there. Part of my decision making process is picking a floor color also. While gray is perfect, it seems boring to me. I may go light blue, no flakes.
cvairwerks
Within hearing distance of Texas Motor Speedway
Light colors, in satin or semi-gloss tend to work the best for spaces where there's lots of work going on. They help reflect light without being too mirror-like, are easy to clean spills from and don't hide things that fall. The downside is that anything that spills and stains will standout if not cleaned up completely before they can attack the coating. Lots of solvents, and petrochemical based things, both liquids and solids, will attack almost any of the normal coatings when left in contact for longer periods of time.
Our hangar floors are semi-polished concrete with some type of sealant, with a light gray mushroom epoxy where the suction danger zone is located. If you look closely, you can see tire tracks on the gray from repeated contact. That tracking comes from hundreds of movements aross the same path, over several years.
Fav Onefour
MN cold and hot
What is the tiny flake stuff called?
I ran across some of that in a campground building in the bathrooms. They used the product on shower floors. It looks and feels like epoxy coat but the flakes are tiny. The floor was grippy and yet seemed like it would be easier to clean vs large flake. The smaller flakes have less camouflage effect. The small flakes didn't look so busy.
In my garage I have large flake with high color contrast and full dense coverage. My woodshop has large flake with low density coverage. I prefer the low density flake coverage when items drop.
S
slomaro3.4
SW Pennsylvania
I considered polishing concrete too, I love how easy epoxy cleans up though. Dope picture!
S
slomaro3.4
SW Pennsylvania
Thanks on the FJ, I’m 100% working in there. I feel like my whole shop’s look right now is sort of bland
LOW1
ontario
I would keep the floor plain and light colored. If you pick something with a lot of flakes in it sooner or later you will get tired of it. And you will also get tired of your wall color. But it’s a lot easier to repaint your walls than it is to redo your floor. So keep the floor neutral and go more aggressive on your wall paint.
FJ4FUN
NorCal
Body coat - LiquaTile 1184 [Silver Gray]
Clear coat - EnduraShield 2255 w/ traction additive
Joints filled w/ SikaFlex 411 in black
Steve W.
Southwest oHIo
First, you need to decide: will be be a WORK place or a SHOW place?
For SHOW, use something that will complement whatever it is you are showing.
For WORK use, use something solid and light. I agree with the light gray suggestions.
My floor? Bare concrete, sealed after finishing, before anything else came in. Has held up well for 10 years.
