I have that saw. I don't use it for work purposes, only for hobby use. Maybe 3 times per year.
The saw is good, but the blades it comes with are garbage. They bend up after about 2 minutes of use. I bought good quality blades (dewalt) and the saw is then okay for hobby use.
The wiring inside the saw came apart, the part where the long plug goes in the tool. I had to disassemble the tool and reattach the wiring.
I also had to change the brushes in the motor, but it came with an extra set of brushes I think. Either that or I took the brushes from a HF grinder, don't remember.
As long as you don't need to use the tool for occupation purposes, and only use it a couple times per year, and don't mind having to modify it about once a year to keep it going, and change the brushes after about 20 hours of use, then not a bad saw. If you are expecting to take it out of the box and have it work right the first time, and continue working daily, then forget about this tool.
