Cebby
Hey all -
Scored a Big Red Air Machine 80 gallon vertical tank and a Schultz MSV30MAX pump. I was told by the seller that they were originally assembled together with a 7.5hp motor which is long gone. Aside from what appears to be remnants of a butchered pressure switch, that's all I have to start with.
I've never had a 2 stage compressor but have been doing a lot of research on what all this needs to be complete and run. Looking for confirmation and or suggestions for alternatives based on my list.
So here's the build list:
Big Red Air Machines 80 gallon vertical tank (HAVE)
Schultz MSV30MAX two-stage 175PSI pump (HAVE)
- has 420mm flywheel ~ 16.535"
- 820 rpm
Leeson 140155 - 7.5hp single phase 1725rpm electric motor (ORDERED-IN)
http://www.leeson.com/leeson/search...ProductDetails&motorNo=140155.00&productType=
Double Groove Pulley 8.0" (online calculator said 7.7/8" dia) (ORDERED-IN)
http://www.ebay.com/itm/121150608778
Check Valve 3/4" NPT (ORDERED-IN)
https://www.mscdirect.com/product/details/63682223
Pressure Switch 135/175 PSI 4 port 26a w/unloader (ORDERED)
https://rite-products.com/air-rite/condor-mdr11-series-4-port-140-175-psi-26-amp.html
Magnetic Starter 7.5hp single phase 220v 40a (ORDERED)
https://rite-products.com/air-rite/...phase-magnetic-starter-40a-220v-50-60-hz.html
Adjustable Motor Mount (ORDERED-IN)
http://www.mscdirect.com/product/details/35439017
Pressure Relief Valve 200 psi 30+ cfm (ORDERED-IN)
https://www.mscdirect.com/product/details/32150955
Cold Start Valve (ORDERED-IN)
http://www.zoro.com/cdi-control-dev...J5JYnDWmKcd8J_mez3X3jBoC5M_w_wcB&gclsrc=aw.ds
Then of course belts, gauges, regulator, drain, etc. but I want to get the big things figured out/ordered.
How's this all look?
- 820 rpm
