apittmanii
- Joined
- Dec 28, 2015
- Messages
- 110
The on/off switch to my 120 volt bench grinder stopped functioning. The old switch (Photo #1) had 2 quick connect terminals that simply interrupted / connected the hot (black) wire to the bench grinder. I purchased a new switch with a 125 volt neon lamp that I would like illuminated when the grinder is “on.” The new switch has the following markings:
McGill Model 0851-1301
SPST On/Off Rocker Switch
15 AMP
3/4 HP 125-277 V.A.C.
Neon LAMP 125 V.A.C.
The new switch has 3 quarter-inch quick connect terminals. When hooked up to the two available wires, terminal 1 and 2 (Photo #2) correctly turn on / off the grinder, just like the old switch. Terminal 3 has NO continuity to terminal 1 and 2, regardless if the switch is toggled to the “on” or “off” position. Photo #3 shows the grinder wiring. Photo #4 shows grinder tag / specs.
My question is this: how do I wire this switch so that the lamp illuminates when in the “on” position? What do I connect terminal 3 to?
15 AMP
