Help required from the knowledge bank.
JasonB1989
Western Australia
Need to fabricate a small steel block that a 6mm air line can pass through and be held. The airline needs to be able to feed through but not return. Similar in principle to a fencing Gripple. Minimal moving parts, and not crush the airline.
What’s your thoughts? I’ve been trying to search the internet but I can’t even begin to think what this would be called.
Thanks in advance.
racingtadpole
The far side of crazy.. but sometimes Australia
Gripples are tension devices. Are you trying to pull the line tight? If so something like a hoisting sock might work, although for 6mm air line you might have to make one, smallest ones I have used barely pull up on cable that’s 10mm diameter. What’s the job? More information brings more specific help.
driftpin
I'd guess a split block, sized for a very-slight interference fit for the hose, and maybe a single threaded bolt to hold the halves together. One through-hole for fastening the block to the bulkhead/wall.
There might be some merit in having a rubber collar providing a bit of tension on the line in the block, to allow a minimal movement with the airflow/use.
Fix Until Broke
SE Wisconsin
I think he's looking for something that he can pull an airline one way, but not let it fall back.
Maybe something like a cam type broom handle holder?
36LH92_AS02
