Help with a NexGen EQC Auto-Dark Lens
SocketDeviler
Texas, 75050
This lens was among a lot of tools I purchased. I have very little welding experience so this thing is out of my league. In hopes of reselling the lens I bought some new batteries for it. The lens instantly came on and responded to function changes but after a few minutes there were spots (ink?) moving slowly around in the lens. After a long while the spots would spread out and the lens would return to one color. Sometimes the spots are there when I turn it on and other times it happens shortly after I start fiddling with the controls. Is the lens defective?, Am I using it wrong?, Something else? Any help would be appreciated. - D.
mtnkrake
Mine does the same thing. I see it more when it is cold out. As soon as I use it the spots go away.
royesses
That is normal. Go to the Jackson products web page and there is a faq. That nexgen EQC is an awesome lens.
S
SocketDeviler
Texas, 75050
From the website.
Q: I see floating dark spots in my EQC filter when the unit is turned off. Is this a defect in the unit?
A: No. What you are seeing is called modeling. It is simply the liquid crystal in the filter separating as it de-energizes in the off state. The dark spots will disappear immediately when you turn the unit back on.
See, what confuses me is that I see the "modeling" when the unit is on. It does go away but not quickly but if you fellas say this is normal I'll take your word for it. I just don't want to sell a defective unit to someone. Thank you!
mtnkrake
It freaked me out the first time I saw it. Mine go away as soon as I turn it on. And yes it is a bad *** lens.
S
SocketDeviler
Texas, 75050
My Snap on (Jackson) auto darkening helmet would do the same, turning the darkness setting to a slightly higher number seemed to help a lot.
Thanks.
I'm curious, does this modeling ever occur while you are welding? If so I would think that would be most distracting if not dangerous.
atari
Carroll, Ohio
I use one every day, In fact I have 2. The spotting happens after it auto shuts down and goes away when you turn it on. Both of mine do it. It never happens when your welding.
S
SocketDeviler
Texas, 75050
Now before I part with this I just want to make sure that this is modeling and it is normal. And I have also noted a rectangular pattern that sometimes shows up on the screen (not shown). Is this also normal? Sorry for the fuss but this thing confuses me. Thank you. - D.
mtnkrake
When mine does it it looks more like blobs/bubbles in a lava lamp. What does it do when you look at the sun? Does it darken?
S
SocketDeviler
Texas, 75050
Sometimes it looks that way but mostly it looks like I posted above. It did not adjust outside in the brighter light (no offense but it's not a good idea to look at the sun) and I could still see the liquid. Oh, well...not the find I was hoping for.
atari
Carroll, Ohio
no, that is not normal. The lens should only do that when its off. I can see in the pictures that it is on and it should be one color. Even when mine shut down and the dots start the are a lot bigger than that. Does it darken as it should when you strike an ark?
