Help with CAT6 wire
Huffduf41
I’m going to run cat6 to my barn from my router in the house to a router out there. It’s going to be a 300’ run.
I know I need direct bury but what other “options” do I need? I know nothing about IT/network stuff.
Thanks
jblnut
In the Middle of MN
"Options" as far as equipment on each end or more on what type of cable you need or what are you asking for ??
If you want more than one device connected in the barn you'll need a switch of some kind to "split" the Cat6 line into multiple available connection points. That can be as simple as any Netgear/Trendnet/TPLink or whatever flavor you can find at WalMart or as complicated as you want if you want to play with a managed switch from the many manufactures of those.
I guess it depends on your intended uses for having internet in the barn. WiFi ? Hardwired things only like most desktopPC's ? TV's/gaming systems ?
yatg
Southern Oregon
300' is pushing the limit of category cable. If the total run from the house router to the barn router is 300' or less and you do a proper installation you should be ok. Any more and you'll need a different method like fiber or wireless. Also consider surge protectors if you're in thunderstorm country.
jdm5
CT
CAT5/6 length limitation is 100m, or ~330'. 300' should be fine.
Definitely get cable rated for burial, but I would put it in conduit as well. And I'd run oversized conduit to be able to replace/upgrade in the future.
checkthisout
Thanks
Fiber is surprisingly cheap. You may want to consider that.
H
Huffduf41
Thanks! I’ll take your advice on the conduit.
Thats including patch cords.
Its 90m for horizontal cable and 10m for patch cords.
We dont know how accurate the OPs numbers are...
u2slow
BC
I doubt it goes full cold-turkey beyond 100 metres. I'm thinking it may not get full gigabit speed. Cat 6 (vs cat5) and shielded likely performs better at max rated distance.
Paul_The_Builder
Dallas, TX
Cat 5/6 will work at 400'-500' all day long, especially at 10/100 speeds like what you'll likely use it for.
Average internet speeds are somewhere in the 30-50 MBPS range (which is plenty of bandwidth to stream a 1080p video), which is 20+ times slower than gigabit ethernet speeds. Even if you get slower speed from a 350' cable run, you won't notice the speed difference unless you're regularly transferring gigabytes worth of data across it.
In short, just run your 300' of direct burial cat6 or regular cat6 in a conduit, and you'll be fine. Don't sweat it.
volleyball
NY, not NYC
Fiber means getting a pro involved. Not newbie stuff. You could use cat 3 for that run though cat6 would be wiser. Reason being that a single cable run won't have interference. And that is the main difference between cat wires.
And planning speeds under 100 Mbs is short sighted. Speed needs/wants will continue to grow, not decrease. Remember when computer memory was in Kbs and people said that is all you would ever need?
Besides running your cable run a pull rope through that conduit. In 5 years you will be planning upgrading.
Dont need a pro for fiber these days.
One can order fiber at desired length with connectors already terminated on.
CAT3 will not work for ethernet wiring. Its not twisted pair.
Only thing CAT3 is good for is phone lines
volleyball
NY, not NYC
Cat3 is twisted, just not as tight. And if there is no interference twists don't mean much. older phone wire was not twisted though many newer ones were.
Fiber takes skills above a newbie as OP stated.
ripperd
Twin Cities, MN
Cat3 is simply not going to work for a 100mbit+ 300' run. Don't do it, and honestly it will be hard to find and not any cheaper than cat6.
For a run like that I'd put in 2 or 3 shielded direct burial cat6. Or a conduit that you can run a new one through later. In the amount of time you plan to use this you probably WILL get it fried by lightning. Hence the bare spares not attached to anything (or a conduit you can pull a new one through).
Honestly though fiber is the better bet for this link. Safer, more future proof, and probably very little cost difference overall. And like another poster said, once you know the length you can get preterminated cable that is no harder to install than cat6.
yatg
Southern Oregon
au contraire.
CAT3 was the standard for 10BaseT wiring in the 80s/90s.
Not that anybody wants to use that anymore.
There were a few other 100BaseT variants that used Cat3 but never took hold.
Good riddance.
Joelfke
Mt Holly, NJ
Im confused, or maybe i missed something. Either fiber or cat6, cant your just run normal cable in conduit? why does it have to be direct burial?
rjacobs
Dallas, TX
Get some Ubiquiti Air Max stuff and beam it... Some of their equipment can send the signal like 30km...
Hook up one side to your in house ethernet and the other side to a switch at the shop side...
ripperd
Twin Cities, MN
Honestly, you could probably get away with regular cable as long as you are 100% prepared to pull a new one through the conduit when it fails. It probably would last for years. I've direct buried regular cat5e cable before for "temporary" purposes and it has held up well for over a year.
collmorgen
Deep East Texas
I just did this for my shop. I used direct buriable cat 6 and a used router to serve as a wireless access point. Gave an IT friend some beer to configure it and it works great.
stuman
I've always wondered when using direct burial cat6 how do you bring it into the house or shop? I'm just used to using conduit to come up from the ground and through a wall.
Sent from my Pixel 2 using Tapatalk
Bad Habit
Chumstick WA
Letter of the law - bring it onto protectors (yes there are Cat 6 rated protectors) and then from there transition to a CM, CMX, or higher UL indoor rated cable depending on the environment that would go through
dave*99
Coastal NJ
Fiber will offer better lightning and surge immunity. Lots of stories about connecting two buildings like yours with Cat5/6. Bad outcomes occur when a lightning strike happens in the area. A direct hit is not required for your sensitive electronics to get fried.
Bad Habit
Chumstick WA
Yes, although for standards based install ( world I live in) it would have to be punch down in/out connections. Very few applications where you can field install a mod end. Do it all the time but again, technically...
Sent from my SM-G975U using Tapatalk
Joelfke
Mt Holly, NJ
Im not a genius so I have no idea what most of that meant.
02chuck
Collegeville, Ca
I just did this to my shop. I ran Cat 6 direct burial cable in a conduit. We use the Google mesh network in the house and I was able to set it up in the shop. The only issue was I had to set up the unit for the shop while hooked up to the wireless network ( in the middle of the driveway) then took it to the shop and plugged it in to the cable.
Loving it!!!
Yes, although for standards based install ( world I live in) it would have to be punch down in/out connections. Very few applications where you can field install a mod end.Do it all the time but again, technically...
The cable for POE microwave radios (excluding APs for wifi) are the only thing i will put a mod end on regardless of standard because they need shielded connectors and it would be a waste to buy a shielded patch panel for 1 or 2 devices.
Haha, thanks for posting, I thought it was just me.
At least there wasn't a string of acronyms and initialisms that I had to look up. :bounce:
He is just referring to the standardization of punching all cables down onto a patch panel 110 block or 110 jack in a biscuit INSTEAD of putting an RJ45 mod end on the cable.
Bad Habit
Chumstick WA
What does "Mod End" mean to the lay person, a simple RJ45 modular connection end?
Correct, the "RJ45" end - MODular end. Also called ice cubes at one point (clear plastic). Use to be that they were only meant for stranded wire, like what is used for cords. Now pretty much all of them are designed for solid wire too. As long as you get the color code and positioning/pairing right, they can easily be installed in the field. Typical caveats, quality tool, good cable prep, etc.
Bad Habit
Chumstick WA
Yeah, we've fought with having to put on mod end on 6A Shielded for POE radios, they wouldn't let us use a shielded jack with a short cord, so had to direct connect the cable into the radio. Belden and a couple of others have developed field installed 6A plugs for shielded cable. Bulky and expensive, but they do work. Question is whether it will fit into the device.
https://www.belden.com/products/enterprise/copper/connectors/cat-6a-plugs
