Help with drill bit selection
decableguy2000
I inherited a box full of taps that I'm sorting through and organizing into Huot indexes. What I need help with is what drill bits to go in the indexes with the taps. HSS, black oxide, cobalt, 118, 135 degree points. to many choices. This is for general purpose set, occasional use. May be used on steel, aluminum, maybe stainless.
pete379
hss , black oxide , 118 about as general as it gets. cobalt is nice in tough steel, as is 135 degree
pete
neonlazer
Lafayette, LA
Norseman Super Magnum, if I am correct, black oxide isn't very good for aluminum and stainless steels.(titanium coating would be better)
sXe
Belvidere, IL
Since you're talking about taps and intend to drill/tap metal, I personally would stay with HSS or if you can afford them Cobalt. If you search some you can find decent Fractional, Letter, and Number set in HSS for fair prices.
LXCam
My good sets are HSS with a 118 and they handle everything I do for both steel and aluminum.
