Help with finding the right box for my project
david5253
Cripple Creek, Colorado
Screenshot 2026-02-11 172625.pngLooking for a clean box 4" x 4"x 2" like this one for a project. Will drill 2 holes for cable glans/clamps on the sides.
But I need a box that has an available cover to accept a Decora receptacle. I know I could use a Steel City type box and cover but for this looks are important. If I only needed one I could custom cut an opening but I need a dozen or more. Any suggestions would be appreciated. Thanks in advance.
CoogarXR
What about a standard plastic double-gang outdoor box? They can use any decora plate you want.
D
david5253
I need a 4x4 box to mount a single decora outlet. Maybe they make a plate to fit a double gang to convert it to a single gang, but I can't find one. Thanks for your help.
mm08822
Make a template/holding fixture and route in the shape with an edge profile bit.
Include 2 holes for mounting.
bugnut
Central Ohio
3d printer search via chatgpt
or ready to purchase
search results
Here are wall plate options that let you cover a double-wide (2-gang) electrical box with a single Decora-style opening (great when you have one rocker switch in a double box and want it covered cleanly):
2‑Gang Center‑Install 1 Decora Switch Cover Plate
$10.95
Kyle Switch Plates
1 Decora Rocker Centered on 2‑Gang Switch Plate
$8.95
Kyle Switch Plates
2‑Gang 1‑Decora Centered Receptacle Wallplate
$8.95
Kyle Switch Plates
Oversized Centered 1 Decora Wall Plate for 2‑Gang Box
O
