I’m trying to rebuild my ProLift 3.5 Ton G-737 floor Jack, and I’m having a heck of a time. Hoping some of you smarter mechanics can lend me some advice.
I’ve replaced all the seals with a rebuild kit, but when I go to pump the Jack, nothing happens. The oil level is correct, and I’ve tried to bleed air out of the system a few times. I think it’s something to do with parts getting improperly rearranged.
I’ve actually been using the parts diagram from an old thread (pic below)
Please tell me where I am messing up:
The far left hole is the cover for the max weight adjustment. I didn’t touch this aside from taking the cap off.
The middle hole is the quick/rapid Jack portion?
The far right hole is some other check valve (inlet?).
What I have laid out is what goes into each hole. Aside from the middle hole, ball bearings aren’t shown in the picture.
I also have 6 balls…but I only need five according to the diagram. 1 for the valve adjust, 2 each for the middle and right holes. Not sure where it came from.
Really appreciate any advice!
