dragonballz
You can see in the picture that the 2nd-floor gutter drains into the 1st-floor gutter. At the point where the 2nd-floor gutter joins the 1st-floor gutter, I believe it overflows BEHIND the vinyl siding because it drips out of the siding's drain holes. In the winter time, I get tiny icicles coming out of those drain holes.
How can I fix this leak? Is there an attachment to force the water to flow left inside the gutter instead of straight down into the gutter? The gutter is already slightly pitched
Thanks
___________________
MORE PICTURES
You can see the original wood shingles behind the vinyl siding in the 3rd picture
