Help with ID of Drill Press?
MechanicalJohn
Seville, Ohio
Any help with identification of my new (very old) drill press would be greatly appreciated. It is obviously a Delta Rockwell drill press, but the only number that I can find on it anywhere is a tag with the number “5310” on it, and that is all that is legible on the tag. No numbers under the lid. I am guessing late 50’s or early 60’s, but no idea.
It has the production table with several “arc of shame” holes, but all in all – the drill press is pretty clean. Dayton 3-phase 1/2HP motor, Jacobs #33 keyed chuck, Allen-Bradley drum reversing switch, Square D push button On/Off switch mounted on side to a very well made bracket. It was used very little at a book binding company.
I paid $300 for the drill press. Did I do okay? I’ve already purchased a KB #9533 VFD for it. Just getting ready to wire it up. Do away with the current On/Off switch and just run the VFD?
Any help is greatly appreciated!!
Provincial
Near Salem, OR
No matter what else, if it runs and the runout of the spindle is good, you did very well. Just the "retirement" light is a big plus.
That big table is a very useful. You will never regret having it, until you have to move the unit around!
Show your photos over on Old Woodworking Machines and I'll bet someone identifies it right away. It is certainly an industrial model.
Whitworth
15" Delta, probably the older utility model, 2 spline drive. The production table is a rarity.
Ken454
Thanks, not familiar with "utility model, 2 spline drive". Will it work as a normal 1/2" drill press?
jmarkwolf
Southeast Michigan
Looks identical to my Delta Rockwell 15in DP500, except for the added electrical box, the larger table, and the rack and crank for raising the table.
Cleave
Back Porch
You're going to love the big table and quill lock, but I don't know how folks clamp down to those tables - I'd want T slots or a grid of threaded holes.
The reversible drum switch would be great for power tapping...
bubinga
You can as you probably know, set up the VFD for reversing. Might even be able to tie the drum switch into the VFD.
liliysdad
With a big, heavy vise, bolting it down becomes a non issue. I have a Cardinal 6B on my DP600 with a production table, and haven't missed the ability the bolt it down one single time.
Looser
Hello Folks, I could use some support with this Garage Sale Find.
This is the data I collected off the Castings, Motor,Stand,Table Ect.
I think it is a DP 220 or 17" from data I have read.
Paid $35.00 Missing the Belt housing/Cover and Capacitor is B.O..
Please educate me on this animal, not looking to do any woodwork, strictly garage shop work. No Vise provided with this machine.
Rockwell Drill Press, Delta Division, Floor Standing 17” Drill Press: Head Casting Number: DP220
Delta – Milwaukee - Rockwell
Serial Number: 62-4513
Stand Casting Number DP204
Table Casting Number: DP200
Motor Information:
MFG: Walker – Turner Company Inc.
Standard 11" square table DP200
Motor Series: The Driver Line
AC Motor: bearings from Accurate Bearing. They are unique as the bearings have an extended inner race but otherwise dimensionally the same as your standard 6203, 6204, 6205 bearing.
Frame: 118E Type: KAB-5E
H.P.: ½
Volts 110 / 220 VAC
Cycles: 60
Phase: 1 – Single
RPM: 1725
Amp’s: 8 / 4
Serial Number: 3275GC1329367
D.P. #220 Head
D.P. #204 Stand
Capacitor Start: A.C. Motor Starting Capacitor
MFG: Mallory
Mf: 340
Voltage: 110 VAC
MFG Model Number: Mallory 3534B4A0340A110B3
Grainger Item #4X067
Capacitor, 340-408
Gator63
Motor Information:
H.P.: ½
Volts 110 / 220 VAC
Cycles: 60
Phase: 1 – Single
RPM: 1725
Amp’s: 8 / 4
D.P. #220 Head
D.P. #204 Stand
MFG: Mallory
Mf: 340
Voltage: 110 VAC
Capacitor, 340-408
Let me know if you are interested in selling the Walker Turner motor.
slowtwitch73
Hellgate
I bolted on a drilled n taped plate to mine.
