Help with Modine 30000 BTU
bhaese56
I live in Anchorage Alaska (about the same climate as where I grew up in Wisconsin actually)
My son has my old house with a 20'x22' insulated attached garage, the two doors have fiberglass blankets but they ARE a little leaky.
I had an old Modine 30K BTU unit and the heat exchanger cracked so I advised my son to get a new one. Instead of the $300 unit from Home Depot I told him if he were going to keep the house a while I would replace it with a Modine, which up here was the best part of $800.
It's been installed but the air does not feel HOT like the old one did. It's firing up and that heat exchanger is hot enough to burn you if you touch it (I know that for a FACT)
If you stand a few feet away it just feels like you're standing in front of a fan, if you get right up next to it it merely feels "warm".
It seems to me like this fan speed is much higher. Is this a matter of the heater working but it just doesn't feel the same? or are the new heaters just not as HOT? I used to get the garage pretty warm with the old unit. I haven't said much yet because to be honest I'm afraid I gave my son some bad advice.
Advice much appreciated!!
hydramatic
Alabama
may have a 2 speed blower. hi is for AC..low is for heat. is it wired for the correct voltage. gas fired or electric. hope that helps
dave67fd
Southern NH
Who installed and set-up the unit? A qualified gas installer would be able to determine if it is heating properly which should have been the case when it was installed.
brewchief
What temp is the garage at when it just feels warm? As the indoor temp rises so will the output temp of the heater.
dragracerz
I dont know if this is a good comparison but I replaced an old 60K BTU furnace w/ a 45K BTU HOT DAWG furnace and it just feels warm compared to the blast furnace that the old one was. It does, however heat and maintain as good as the old one, but isnt any cheaper to run and the old one had a standing pilot and was 15K BTU more output
