Help with switch
bluedog225
Texas
IMG_9162.jpegIs the intention here that I snap the tabs off the switch so it will fit this plate?
Or do I simply have the wrong switch? And does the correct switch have a designation?
Many thanks.
bluedog225
Texas
Thanks. I was hesitant just to tear stuff up to make it fit. But it looked like that might be the way this was supposed to work.
johnre
Portland, OR
Also, remove the mounting screws that are intended for a J-box mounting - otherwise the screw heads will high center on you against the cover.
Edit: Never mind, @LXCam beat me by a millisecond!
