Help!!!!!!
nb2841
acid eched my floor a few days ago and put the first coat of epoxy coat on last night. the fiber in the concrete came up a little bit and looks bad. what should i do? i am going to put a second coat of base (with sprinkles) this afternoon. and clear coat to follow after. any suggestions ?? thanks
rugerlady
Agreed! The fibers should have been burned off with a torch before applying the epoxy. At this point your option would be to sand and recoat.
K'ledgeBldr
Johns Creek, GA
Last time I looked- fiberglass doesn't burn.
Fiberglass has a softening point of 1555°F and a melting point of 2075° F.
And I very seriously doubt you'll get that out of a "torch" (with exceptions of course).
Pcchase
Fiberglass burns very well.
Edger
Melbourne Australia
Cure, sand and recoat. Good luck because it will be very hard to sand with anything less than diamonds and then it will be difficult not to cut through the coating. You will not be able to sand it like normal house paint.
AlphaGarage
Every Garage, AnyTown, USA
Don't know the melting or flash point fo the fiberglass. Don't know the temp at the head of a propane torch. Do know that plenty of contractor and DIY clients have used propane wands to successfully mitigate fiberglass before applying resin coatings.
Propane wands are used for a variety of reasons - deicing sidewalks, weed abatement, torch down roofing, cooking chickens on the run, dealing with fiberglass in concrete before coating with epoxy.
There are times when the fibers are almost impossible to see beforehand. What happens is that when coated they swell up and a seemingly non-issue becomes a big issue.
We had one client swear that our epoxy just formed these small spikes all by itself. Took some time to eventually convince him to get on his hands and knees to look at a spike with a magnifying lens - sure enough he could then see the tiny fiber in the middle of the spike.
If they're not too pronounced you could just coat over them. The next coat of epoxy will cover them to a degree, and depending on the density the flakes will also mask them. It's very much a case by case situation.
It may be easier to just buy more flakes and do a very heavy broadcast.
N
nb2841
i ended up rolling another base coat and casting sprinkles. you can not tell at all.
