Help
FiendFX
California
My key fob battery died so I attempted to open the screw to replace the battery but the screw is busted. Help?
zkling
Is it a large plastic screw on cap? The ones I have seen are actually designed for a coin and not a screwdriver :dunno: A picture would really help on this. :beer:
zkling
Picture? What do you mean by "busted" did you strip the screw head out?
F
FiendFX
California
yes. the screw is stripped. i'm asking to see if anyone has successfully done it without replacing the shell.
Duarte
Even if stripped, you may be able to use a jewelers flat head or a Torx driver to remove it.
PugetDude
Superstition Mountains, AZ
A picture would be helpful, otherwise you're just asking for blind advice ...
So, based on no photo, hypothetically you might be able to use a dremel to grind a screw slot in the stripped out screw head and use a small flat-blade screwdriver to remove it. Even if you cut into the plastic case a bit, it shouldn't hurt the functionality of the fob as you didn't cut all the way through into something electronic.
G_P
Central CT
Use a precision flathead screwdriver to remove the stripped screw and replace the screw.
Or buy a new FOB off Ebay. At worst you will have to bring it to a dealer to get it programmed to the car but most can be programmed at home. Google make and model to find out how.
