From my understanding, the top unloader and front unloader is for continuous operation mode, which I do not want to run the pump in.
Currently my setup has a 1/8th fitting off the check valve that leads to the pressure switch, and when the pressure switch turns off, it unloads the pump. Is this all I need with this pump?
Do I NEED to connected those two fittings somewhere if I will not be running continuous mode? If I don't do I need to cap them or can I just let them vent when the pump turns off?
Sorry for all the questions, I never dove into 2 stage pumps before.
Edit: zkling didn't see your post until after I posted mine, I don't know who makes the pump, it has Compressor World stamped on it, seems to be a copy of an Eaton, but it was $375 shipped and has a 1 year warranty on it, so only time will tell.
